Akai MPD32
  • reitek
    Akai MPD32
    by reitek » Mon Apr 16, 2012 8:09 pm
    Hey guys, for some reason my mpd32 is acting screwy. Whenever I press the drumpads it affects other random parameters in modul8 I don't even have mapped to the mpd32. Sometimes I'll press a pad and it'll change the RGB vales or the Alpha master output. Sometimes it'll shut the layers on and off. I don't know why it's doing this. Anyone have similar problems with the mpd32? Are there any fixes?
  • anomad
    Re: Akai MPD32
    by anomad » Mon Apr 16, 2012 11:01 pm
    . do you see MIDI data coming in from the Akai using MIDI Monitor (http://www.snoize.com/MIDIMonitor/) other than what you're expecting ?
    . have you tried disabling all of your modules and seeing if the behavior continues ?
    . have you tried deleting your Modul8 preferences ? (search the forum for how to do that)
    -james
    (a nomad. )
  • reitek
    Re: Akai MPD32
    by reitek » Tue Apr 17, 2012 5:27 am
    http://imageshack.us/photo/my-images/40 ... at112.png/
    I took a picture of my midi monitor. I held down one of the pads and it send out all kinds of messages. I don't know why it's doing that :?:
  • anomad
    Re: Akai MPD32
    by anomad » Thu Apr 19, 2012 1:37 am
    . that's fine - it looks like it's sending channel pressure for the pad
    . have you tried turning off all modules and seeing if the weirdness is still happening ?
    -james
    (a nomad. )
  • reitek
    Re: Akai MPD32
    by reitek » Fri Apr 20, 2012 4:42 am
    Yup. Tried shutting everything down and restarting. I'm just gonna send it back and get an APC40. It's what we use at the club I work at and it works fine. I have a good setup for it. I just liked the mpd32 because it had those pads.
    orion
    Re: Akai MPD32
    by orion » Mon May 21, 2012 8:28 am
    i had this problem you just need to edit the mpd32 and change the settings for each pad in each bank then save that for reuse.
    on the 32:: press edit > press enter > then touch the pad you wanna change > then change the middle value MTY to TGL
  • timabad
    Re: Akai MPD32
    by timabad » Thu Sep 20, 2012 5:19 am
    Thank you!
  • reitek
    Re: Akai MPD32
    by reitek » Sun Feb 10, 2013 11:17 pm
    Excuse the uber delayed response but Thank you!!
