Wrong Dimension when exporting PDF OUTPUT
  • the9ismine
    by the9ismine » Tue Apr 24, 2012 10:31 am
    Hi guys,
    i have a problem. i want to export the output as a pdf but i doesnt quiet work right.
    my canvas is 800x600 but when exporting to pdf it's 842x595, which makes it pretty hard to work further in illustrator or after effects because you have to align everything once again. seems weird to me. same goes for svg.
    Bildschirmfoto 2012-04-24 um 10.24.59.png (15.5 KiB) Viewed 4413 times
    Bildschirmfoto 2012-04-24 um 10.26.26.png (12.92 KiB) Viewed 4413 times
    when i export to png the dimensions are correct. but i cant do any work with a png because its all baked into one layer.
    Bildschirmfoto 2012-04-24 um 10.25.18.png (10.08 KiB) Viewed 4413 times
    anyone has the same issues?
    Re: Wrong Dimension when exporting PDF OUTPUT
    by sigmasix » Tue Apr 24, 2012 10:50 am
    oohh, I have the same issue…
    Prefer exporting in SVG, this has the right dimensions!
    The bug is now noted
  • the9ismine
    by the9ismine » Tue Apr 24, 2012 12:56 pm
    yeah you are right.
    dont know why i thought svg wouldn't work but it does. thanks!
    Bildschirmfoto 2012-04-24 um 12.55.19.png (34.41 KiB) Viewed 4406 times
