What aspect ratio for project?
  • Basic
    by Basic » Tue Apr 24, 2012 8:48 pm
    Hey Guys&Gals,
    I have a gig where i will be performing onto an LED wall. The resolution of the wall is 480x130 so my aspect ration is 48:13.
    How would i set this up? what preview aspect ratio do i need and would i need to use the advanced output?
    I will be plugging into this wall via DVI straight for my MBP.
    Thanks
    Basic
    deepvisual
    Re: What aspect ratio for project?
    by deepvisual » Tue Apr 24, 2012 9:58 pm
    you need to work within a standard res, using an image safe area the same proportion as your screen, which can be scanned up to fit.
    I'd suggest you use 1024 x 768 which is pretty standard.
    always a good idea to talk to the screen boys... they are usually pretty friendly.
  • Basic
    by Basic » Wed Apr 25, 2012 2:03 pm
    Cool, thanks Deeps, this makes sense. I'll give that a go. I standardly work at 640x480 - thank god for modul8 haha.
