about sorensonand photo jpeg
  • joinmckay
    by joinmckay » Fri Apr 28, 2006 3:26 pm
    Hi,my doubt is, people say about this codecs (sorenson y photo jpeg) but i just take a videos and send final final cut, after i edit and make loops, cutting, etc and export like avi,mpg4,etc so i open my modul8 and import videos and ready for performance, but what is de paper of (sorenson and photo jpeg) this codecs are into the final cut when i export?
    or i have to download codecs in the internet?
    or there is a specialy program what have this codecs?
    how i get this codecs..... into the modul8 maybe?
    thanks for your aid and sorry for mi english 8)
    joincmkay
  • Akira
    by Akira » Fri Apr 28, 2006 6:15 pm
    I couldn't understand your english. Perhaps it's best to post in the Spanish forum>?
    If I undertsood sometingm, you can export directly from FCP into those codecs using Quicktime COnversion. Read your FCP manual :?
  • mannikin
    Re: about sorensonand photo jpeg
    by mannikin » Wed May 03, 2006 7:47 pm
    Sorenson & Photo Jpeg are automatically installed when you install Quicktime. So, if you are already using Final Cut Pro, Quicktime is definitely installed, and you should already have those codecs installed. The best way to do it within Final Cut is export to Compressor, and do all your compression from there. (compressor is part of the final cut studio installation).
    J.
    joinmckay wrote:Hi,my doubt is, people say about this codecs (sorenson y photo jpeg) but i just take a videos and send final final cut, after i edit and make loops, cutting, etc and export like avi,mpg4,etc so i open my modul8 and import videos and ready for performance, but what is de paper of (sorenson and photo jpeg) this codecs are into the final cut when i export?
    joincmkay
    S Y N F O N Y<> S T U D I O S
    powerbook G4 15"
    Tiger / 2GB RAM
    Korg microKontrol
    modul8 V2
    http://www.synfony.com
