preview background
  • esb2001
    preview background
    by esb2001 » Thu Apr 26, 2012 4:28 am
    every time I change the preview background to the image I am mapping on, it imports it sideways. why? and how do I change this?
    thanks
    esb
    Re: preview background
    by franz » Thu Apr 26, 2012 10:17 am
    what do you mean by sideways ?
    upside down ? flipped ?
    I've never seen this...
    What is the file format of your image ? jpg ?
  • esb2001
    by esb2001 » Thu Apr 26, 2012 2:41 pm
    So instead of importing right side up, it is turned 90 degrees onto its side.
    Esb
    by franz » Thu Apr 26, 2012 3:04 pm
    Can you please contact the support, and send them a link to your MadMApper file + background image.
    They'll look into this issue ASAP.
    by franz » Sun Apr 29, 2012 6:45 pm
    Hi again,
    I've been unable to reproduce your problem.
    If anybody shows up with a step by step explanation on how to reproduce the problem 100% of the time,
    I'll be happy to send this person a free MadMapper TShirt as a gift for helping us correcting a bug.
  • sanemapper
    by sanemapper » Wed Aug 21, 2013 3:11 pm
    Hey Franz!
    I am having a problem with the preview window. I have set the stage size to 1920 x 1080. When I load a preview jpeg which is 1920 x 1080 it goes tiny up in the left corner of the stage
  • nataraja
    by nataraja » Tue Aug 27, 2013 2:07 am
    Hi All, Franz
    happy to see this post.
    I have same issue on 1.5.1
    as soon i load an 2400 x 600 jpeg image into the preview background, it's is showed to much on the left. The high is ok.
    Lets say my preview is 2400 divided into 3 spaces, 0, 1 and 2 ... the image take space -1, 0 and 1 !!
    hope you understand ..
    thanks
    sacha / nataraja
    nataraja.veejay.ch
    by franz » Wed Aug 28, 2013 12:41 pm
    are you using the background via the Output/Projector tab ?
  • nataraja
    by nataraja » Thu Aug 29, 2013 1:02 am
    No, just loading a 2400/600 image via the menu View and then change the background preview....
    sacha / nataraja
    nataraja.veejay.ch
    by franz » Thu Aug 29, 2013 7:38 am
    so maybe you have to set the stage size (in the master tab) to 2400*600 first.
  • nataraja
    by nataraja » Wed Oct 02, 2013 12:53 pm
    franz wrote:so maybe you have to set the stage size (in the master tab) to 2400*600 first.
    Hi Franz,
    My issue has been resolved with the 1.5.2 upgrade ....
    good so ...
    sacha / nataraja
    nataraja.veejay.ch
