spacial scanner
  • esb2001
    spacial scanner
    by esb2001 » Thu Apr 26, 2012 3:40 pm
    when I engage the spacial scanner, for some reason the lines the projector is supposed to display on the object displays on my desktop. Once on desktop it cannot be moved. all my other outputs work properly. any advice out there?
    Re: spacial scanner
    by franz » Thu Apr 26, 2012 5:10 pm
    which version of MM are you using ?
    What is your os/gfx card ?
    What camera are you using ?
    First time we hear of this behaviour...
    Are you sure your projector is connected ?
  • esb2001
    Re: spacial scanner
    by esb2001 » Thu Apr 26, 2012 5:49 pm
    MM 1.2
    mac book pro, snow leopard, Nvidia's GeForce 9400M
    canon EOS rebel xs
    yes, projector is connected. when I open full screen output for basic projection, the projector displays properly. But, when I open up the scanner, and hit scan, the image the projector is showing is now the desktop, and my lap top screen has numerous lines and flashing.
    Re: spacial scanner
    by franz » Thu Apr 26, 2012 7:33 pm
    does MM correctly sees the Rebel XS ?
    Do you have the preview from the camera in MM ?
    (it should be listed in the avaiable camera, along with the isight)
    I have a Rebel XT at the office, it works, but I haven't checked with a rebel XS.
    Meanwhile, can you contact the support, as your problem is rather strange/unusual
  • esb2001
    Re: spacial scanner
    by esb2001 » Thu Apr 26, 2012 7:42 pm
    yes. MM recognizes the Rebel and I can see a preview. What I do not see, or do not have an option of choosing, is the size of the output, located next to where the available camera is.
    Re: spacial scanner
    by franz » Thu Apr 26, 2012 7:50 pm
    please contact the support.
    meanwhile, open up the console app.,
    repeat the procedure, and send the console output to the support.
  • Jon121
    Spacial Scanner and Grid Warping
    by Jon121 » Wed Jul 11, 2012 10:43 pm
    Can you use the spacial scanner and a camera to create a layer file of a 3 dimensional box structure and then turn into grid warping for each layer with about 38 sections in a short space of time?
