Lotsa red dots....
  • Projectionfreak
    Lotsa red dots....
    by Projectionfreak » Sun Apr 29, 2012 6:47 pm
    Quick question on whether this will run or not:
    I'm looking to see if I have this set up right for optimal performance.
    Macbook Pro, 16gb RAM, 2.2 gHZ quadi7, Radeon 6750m
    Clips are on an external 1 TB. RAID 0 on FW800
    Clips are 1280x720, PJPEG at 70%
    Outputting to Madmapper
    Some of the clips are rather large (1.5-3gb) but they also don't have a lot of motion/moving info in them. Some are just static images, but they last a long time. Should I set the RAM preload to 'Direct to disk' or 'RAM preload'?
  • Projectionfreak
    Re: Lotsa red dots....
    by Projectionfreak » Mon Apr 30, 2012 5:48 am
    I should add there are 54 clips in all...about 140gb total.
    by The Midi Thief » Mon Apr 30, 2012 3:30 pm
    Just remember, a 3GB file is not 3GB in the memory when it's preloaded or preloaded uncompressed.
    Select your media in the Media Set and press the i-button to get info about your media and you'll see how big the files are in the memory using the different loading methods. Having such huge files preloaded won't work.
  • Projectionfreak
    by Projectionfreak » Wed May 02, 2012 5:18 am
    Well it would appear that my setup does indeed play all that media. I think the combo of a FW800 raid and a boatload of ram is all its cracked up to be. I can sleep now....
    Thanks Modul8!
Users browsing this forum: No registered users and 164 guests
