Timed preset changes....
  • Projectionfreak
    by Projectionfreak » Wed May 02, 2012 3:05 am
    Ok I have a bunch of presets. I have media in Modul8. Some MM presets correspond with that media, but when I change from preset to preset (whilst a media transition is happening in M8), it 'snaps'. Any work arounds to make a timed transition in MM (ala smoooooothly from one preset to another)? Does this make any sense?
    Thanks in advance..and thanks too for such an amazing piece of software. It has truly opened up some new worlds for me!
    Re: Timed preset changes....
    by franz » Wed May 02, 2012 10:22 am
    one workaround is to blackout before changing the preset
  • Projectionfreak
    by Projectionfreak » Wed May 02, 2012 9:18 pm
    Yep...got a few of those, but most are 'live and in the open'. Switching when blacked is great....maybe a feature request....
  • rihmjihm
    by rihmjihm » Tue Apr 21, 2015 1:55 pm
    There are many way to do it. One I have done in the past that is fairly simple is masking the outside of the image then copying the mask, invert it and make it slightly smaller. You should now have an outline of the shape. Now any color movement behind these 2 layers will seem to be a line.
    You can get score highest marks in VCP550 dumps dumps exam using and test 640-864 exam king which are prepared by top certified professionals, Tabor College ccna wireless training; both are marvelous in www.the-bac.edu
    aktion
    by aktion » Wed May 20, 2015 9:47 am
    Try this.. it will blow your mind http://vezerapp.hu/
    what this essentially does is acts as a virtual midi controller so you can set events based on a timeline and add smoothing, precise time based multi-trigger options.
    I had an event i did where i needed to switch between presets sometimes within seconds and at exact moments so i automated my whole show on it.
    This is one of the best complimentary app you can use to automate your show.
    hope this helps.
    AKTION STUDIO
