Using hexagons to map?
  • MattJsy
    by MattJsy » Sat May 05, 2012 7:51 pm
    Hi Guys,
    Firstly lovely piece of software excellent work!
    I am playing with the demo and am sure I will be buying this when the time comes (c:
    I was wondering it is possible to map with shapes like a hexagon? I have tried using a mesh to do this but you then have to warp the video and map with rectangles still.
    Any help appreciated.
    Matt
  • scaryxpuppy
    Re: Using hexagons to map?
    by scaryxpuppy » Sat May 05, 2012 8:25 pm
    In version 1.2 (hops this is the demo you have) - you can create MASKS that are specific to a layer...
    These masks enable you to create perfect shapes every time, whilst still allowing for perspective transformations
    The masks can be inverted as well, which is a great feature to use the original MASKING as the output !!
    Hope this gives you the ideas you need....
    PS - Do buy the software ! You won't regret it
    PHIL
  • bareimage
    by bareimage » Thu May 10, 2012 7:34 am
    Phill what he is trying to do is to create mesh distortion. Mesh is often done from poligons.
    Right now you can't. MAX6 it is possible :|
  • 1000errors
    by 1000errors » Fri Jun 29, 2012 7:00 pm
    Yes you can map hexagons very easily, just create a square, turn on mesh warping, set the first box to have 1 subdivision and the second to have 2 subdivisions, turn on "show input mesh", you will then see you have 6 points in total, now just drag the points to align with the 6 corners of the hexagon shape.
    There's no need for any masking doing it this way.
    I use hexagons alot, you can see some examples of them on my website. http://www.1000errors.com
