MadMapper and Watchout
  • TheMonkeysCobbler
    by TheMonkeysCobbler » Wed May 16, 2012 7:44 am
    Hello, Can anyone please help me figure out how to use Mad Mapper and WatchOut together for projection mapping?
    I am finding it very hard to find information.
    Thank you!
    pele2010
    Re: MadMapper and Watchout
    by pele2010 » Wed May 16, 2012 9:18 am
    Hi ,
    i just did that on 2 Shows.
    There are basically 2 Ways to do this.
    1. If you use watchout as timeline and to do the geometry and the blending, you feed modul8
    through the video I/O of watchout.
    but there are some restrictions. You cannot trigger this signal. i mean you can but it behaves like a
    camera you hock to the system.
    2. You use Modul8 as the final system.
    Then you need to feed watchout through the video I/O of MD8.
    Now you´ve got the control of the timeline through watchout and this timeline is used as
    a layer in MD8.
    But you need to do the softedging and geometry in MD8 or with the projectors.
    Ok . there is a 3 Method:
    We also used a video switcher to switch in-between the sources. (or mixer)
    As far on how exactly you connect both systems you should book an operator that has done this before.
    There is a Watchout Forum:
    http://dataton.com/forum/forum/2-watchout-forum/
    And i think it should be no Problem to get an experienced operator.
    The operator is not only a technician, he also guides you through the show.
    I hope this helps you
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    deepvisual
    by deepvisual » Wed May 16, 2012 3:00 pm
    have to ask why?
    mad mapper is mac based, watchout is pc.
    by franz » Wed May 16, 2012 3:12 pm
    all the more as, apart from the timeline, the combo modul8+madmapper can act as a cheaper alternative replacement for a watchout
    pele2010
    by pele2010 » Wed May 16, 2012 4:03 pm
    HI deepvisual and franz,
    if you need to work with more than 3 projectors.
    We had 5 Projectors for a cylinder .
    Or is there a way to handle this with mad mapper ?
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
