sound-in invert
  • koliak2991
    sound-in invert
    by koliak2991 » Thu May 24, 2012 12:26 am
    hey all, been playing around with and learning modul8 for a few weeks now and have hit a bit of a problem.
    I want modul8 to automatically invert the colors of the image (like the sound-in function for autocolor/autorotate/etc). is there a module or any way I can possibly do this without doing it manually?I find it a bit tiring after a while trying to keep up with the beat as well as doing a million other things at the same time. any help would be much appreciated, thank you!
    cvanhoose
    Re: sound-in invert
    by cvanhoose » Fri May 25, 2012 8:30 pm
    There are several ways to do this. Auto color has options in its tab. Plus and minus options. Enable sound level.
    I use a bpm module and link the pace to the layer using the bpm routing module. You can then tap to program your speed, a midi clock option is also available. Look into waveclock for the midi clock option. It's rather expensive in my opinion.
