Manual Search and problem with madmapper
  • dj.leoneleone
    by dj.leoneleone » Tue May 29, 2012 10:23 pm
    Hi, I recently bought madmapper but I have a manual, where can I look? I have a problem that can not risolvere.Il mad when I switch it on my black screen appears and I can not remove this feature if not only cuts off the power by turning off the PC. there a command or set of keys to return the window My basic madmapper? :oops:
    pele2010
    Re: Manual Search and problem with madmapper
    by pele2010 » Tue May 29, 2012 10:46 pm
    i guess you need to enter "cmd T" (command T)
    this exits the "full screen mode" ....
    When you enter this mode , you are told the short cut though.
    hope that helps ......
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
