Clips Randomly Restart
  • PhantomActual
    by PhantomActual » Mon Jun 18, 2012 5:52 pm
    I'm having an issue with Modul8. I'm using it as a syphon host for a 8 projector setup funneled through three triple head to gos. I have one large movie roughly 10gbs in MJpeg A with audio. For some reason it hits a certain point in the clip and just restarts the clip. Does anyone know why this might be occuring and what can be done to fix it?
    Re: Clips Randomly Restart
    by ilan » Tue Jun 19, 2012 9:07 am
    First, try converting to the clip to PhotoJPEG codec. Also, check if you are using any modules that control playback and shut them off to see if the module is causing this to happen.
