Edit Filter with a Module
  • Spjoni
    by Spjoni » Thu Jun 21, 2012 4:14 pm
    Hello Everybody
    I want to connect the LB-SmoothChanges Module to the Radius from the FilterEffect HoleDistortion.
    For the reason, that the Hole grows smooth... I trigger the HoleRadius with OSC and this is to jumpy. If i will set the smoother between... that would work, but i dont know if this is possible...
    Can anyone tell me, if a can Connect a Filter with a Filter/Module?
    Thank you so much!
    Spjoni
    www.projektil.ch
    visual-art-entertainment
    Re: Edit Filter with a Module
    by The Midi Thief » Sat Jun 23, 2012 8:35 pm
    Nope. You have to code your own module or alter the code of the LB-SmoothChanges Module to connect to the FilterEffect HoleDistortion. It's probably just a few lines of code but there are other people here that have dealt with the filters more that probably can give you a better reply.
  • anomad
    by anomad » Sun Jun 24, 2012 7:47 pm
    . i've worked w/some filer effects in modules (120 avFX) so maybe i can offer some insight...
    . as i understand the effects system, you basically update the effect information, clear the filters, then push the changed effects into the filters...
    . so, you want to use : {'FILTER': '(CI) Hole Distortion', 'PARAMETERS': {'Center Y': 0.5, 'Center X': 0.5, 'Radius': 0.0}}
    . quick sidebar - how did I know the definition? i edit the 'Filter (layer)' module and have it print out the effects being used...
    . in the 'Filters (layer)' module, in Init() towards the bottom - uncomment the '##print filters' line and Cmd-Option-O to see the output
    Code: Select all
    def setFilters(): filters = [{},{},{},{}] for i in range(0,4): if enabledPass[i]: filters[i] = filtersPass[i] modul8.setFilters(filters, 0, postFilters) ##print filters <------- uncomment this line! # Last initializations
    . i would suggest re-commenting that line once you get the definitions so you don't waste resources printing stuff out.
    . ok, so now you have a dictionary item of your effect...
    . in Init()
    Code: Select all
    myFx = {'FILTER': '(CI) Hole Distortion', 'PARAMETERS': {'Center Y': 0.5, 'Center X': 0.5, 'Radius': 0.0}}
    . somewhere in your code, you want to assign the variable that is doing the smoothing to the myFx['PARAMETERS']['Radius']
    . then in PeriodicalEvent() something like
    Code: Select all
    myFx['PARAMETERS']['Radius'] = varThatIsSmoothing modul8.setFilters([{}],0,False) modul8.setFilters(myFx,0,False)
    . good luck! :)
    -james
    (a nomad. )
