Getting MadMapper shape coordinates?
  • Vibber
    by Vibber » Tue Jun 26, 2012 10:27 am
    Hi there,
    I am looking for a way of exporting the coordinates of the shapes I draw in MadMapper - be it squares or polygons. I thought perhaps I could just open the .mad file in a text editor and though I can see some text it's not clear to me if it's saved in some commonplace file format. I am prepared to do some work understanding and cleaning up the data so could you tell me the file format of the .mad file. Perhaps there is a viewer or utility of some sort I can find to view the file correctly.
    The reason for my request is that I would like to be able to programmatically recreate a quite complex structure of input shapes instead of having to redraw them manually from an exported MadMapper picture.
    Re: Getting MadMapper shape coordinates?
    by sigmasix » Tue Jun 26, 2012 11:01 am
    You can export an SVG file which has all the coordinates in XML format.
  • Vibber
    by Vibber » Tue Jun 26, 2012 12:52 pm
    Aha, nice. I Didn't know that about SVG. Thank you :-)
