Is the best codec/compression for M8 still PhotoJPEG at 75%.???
Just checking as I'm about to batch convert my entire archive and would rather not do it twice if the recommended codec has changed in recent versions.
There are few equally good ones. I use mostly Livid Batch ExporterBTW what do ppl recommend as a good batch convertor?
