issues selecting multiple shapes and moving them
  • jerms
    by jerms » Sun Jul 01, 2012 10:49 am
    I've found that once I have my project set up and I select multiple shapes and move them to create different configs of inputs, some of the shapes distort and fly off the screen, or it deselects everything and only selects the shape I grab. I have tried different methods, ie. drag select and grab last shape selected, select only 1 type of shape etc, it seems to happen randomly. The only way it seems to work 100% of the time is to manually command select 1 at a time. This is super annoying, and inhibits my workflow. Does anyone else experience this?
    We are running:
    Processor 2 x 2.4 GHz Quad-Core Intel Xeon
    Memory 32 GB 1066 MHz DDR3 ECC
    Graphics ATI Radeon HD 5770 1024 MB
    Software Mac OS X Lion 10.7.4 (11E53)
    modul8 2.6.4
    madmapper 1.2
    triplehead2go to 3 projectors
    blackmagic intensity pro for input into modul8 from video mixer
    thanks
    jon
    screen shot
    Screen Shot 2012-07-01 at 1.48.12 AM.png (255.31 KiB) Viewed 13171 times
    Re: issues selecting multiple shapes and moving them
    by franz » Tue Jul 03, 2012 6:41 pm
    does it happen with any surfaces ? (like quads) or only on specific surfaces ?
    Does it happen only when the snapping is enabled, or all the time ?
    Can you post a step by step to reproduce your problem ? (or a MM file that illustrate the problem)
  • jerms
    by jerms » Thu Jul 05, 2012 6:23 pm
    seems to be any surfaces,when I drag select many at a time, then try and move them together, although more with quads and triangles thans circles
    when snapping is on or off, I believe snapping was off when I took this screen shot, but I would have to test
    unfortunately I will have to post the madmapper file when I go back to Vancouver as the mapping computer is there, I will be back there next week
  • jerms
    by jerms » Sun Jul 22, 2012 10:25 am
    1.drag select all shapes here
    Screen Shot 2012-07-22 at 1.16.46 AM.jpg (170.49 KiB) Viewed 13092 times
    2 try to move them they warp and distort and fly off screen, or all are deselected and only shape that you grab is selected. reselecting multiple times it may work. using command select it works, but this is slow and tedious.
    Screen Shot 2012-07-22 at 1.17.11 AM.png (114.82 KiB) Viewed 13092 times
  • FranzKarl
    by FranzKarl » Fri Aug 24, 2012 1:32 pm
    I'm curious to know because I had sometimes de same troubles with distortion of the masks or surfaces, and I also need to move several surfaces together or rescales them together but it bug à little and I want to do it facter ! Maybe my graphic card is too slow, I have a macbookpro :
    MacBook Pro
    Intel Core 2 Duo
    Vitesse du processeur : 3.06 GHz
    Nombre de processeurs : 1
    Nombre total de cœurs : 2
    Mémoire : 8 Go
    NVIDIA GeForce 9600M GT 500 Mo
  • FranzKarl
    by FranzKarl » Fri Aug 24, 2012 2:09 pm
    And now I have to go back to version 1.2.1 because I just received the e-mail with update to 1.2.3 but when I want to select several edges from multiple surfaces together, madmapper crash, I tested it 10 times....
  • jerms
    by jerms » Sat Aug 25, 2012 12:10 am
    I am highly curious too as no one has made any suggestions on what the issue is, or could be, I doubt it is your graphics card, this is a bug in the software
    cvanhoose
    by cvanhoose » Sat Aug 25, 2012 4:21 pm
    The team is under a rock....they have not replied to any of my issues reported either. They lost me as a user and promoter for Modul8, please keep me as a user of madmapper! VPT has an awful interface.
  • FranzKarl
    by FranzKarl » Sat Aug 25, 2012 6:38 pm
    I had a scenarised live yesterday night, it was easy with madmapper, but it would have been 10 times faster if I could resize several surfaces together. Like in photoshop and illustrator when you want to resize several selections with "transformation".
    @cvanhoose : madmapper is awsome, but still young and need to evolve, modul8 NEED to evolve, interface is old now. Thx for VPT, I didn't knew and will look it closer !
  • jerms
    by jerms » Sun Aug 26, 2012 1:00 am
    @franzkarl I would suggest you put that in feature requests as it really has nothing to do with this thread.
    by ilan » Mon Aug 27, 2012 5:30 pm
    @FranzKarl. Can you send your report to support? We can bettet assist you there. When you do, please clarify for us what you mean by 'edges' as the only methods are selecting points.
    Thanks in advance.
    by boris » Mon Aug 27, 2012 5:40 pm
    Juste a remember if you expect an answer from the team is recommanded to send a message directly to the team in the support and not in the forum who is more dedicated to providing user to user based support.
    We are usually answer messages within 48 hours during the week (we are humains and take weekend as well).
    There is a note about that :
    viewtopic.php?f=21&t=5652
    Boris.
    by boris » Mon Aug 27, 2012 5:41 pm
    If your bug is true, you will receive a free t-shirt.
    ilan wrote:@FranzKarl. Can you send your report to support? We can bettet assist you there. When you do, please clarify for us what you mean by 'edges' as the only methods are selecting points.
    Thanks in advance.
    by ilan » Mon Aug 27, 2012 6:50 pm
    True what he writes about the weekends, but I usually answer messages on the weekends as well.
