Locked 2 posts Page 1 of 1
low fps with AutoFulscreen
  • Dodjix
    by Dodjix » Mon Jul 02, 2012 7:30 pm
    For an exibition I have done an appleScript to run an OpenFrameWorks app and madmapper in fullscreen.
    It's work but the fps is vers low (10 fps). And when I left the fullscreen the fps Run normally, and after I can
    rego In fullscreen and all work good. Anyone Has Has solved this problem ?
    thank you bye
    Dod
    Re: low fps with AutoFulscreen
    by franz » Mon Mar 04, 2013 7:32 pm
    if you need fullscreen on the main screen, there's an option in the preferences called:
    "Show Fullscreen on Main screen at Startup", which will just do that
    (intended for headless autonomous installations)
