Is it possible to stream Images?
    piero101
    by piero101 » Fri Jul 20, 2012 5:36 pm
    Hello everybody!
    So, here’s what I want to do:
    Basically I want to have one file (an image or a movie) and I want to play with it in realtime. But the file should constantly stream new images which I’ve collected beforehand and put together in a folder.
    Is there a way to do such a thing?
    Is it possible to use a huge bunch of images which replace themselves automatically without me having to select every new image manually?
    Thank you very much for any idea!
  • Seethings
    Re: Is it possible to stream Images?
    by Seethings » Sun Jul 22, 2012 10:42 pm
    Drag a folder of images from desktop into media bin. It will play all images in succession. You can set the rate with the speed parameter.
    piero101
    by piero101 » Mon Jul 23, 2012 12:42 pm
    Wow, that was easy! :D
    Thank you very much!
    Do you have any experience with that?
    Is there a limit of images I can use before it affects the performance?
