m-audio output works, but no sound in!!
  • t-xis
    by t-xis » Sun Jul 22, 2012 10:48 pm
    heeeelp,
    i´m getting crazy trying to get the "sound in" working via my m-audio fast track usb audio interface. the output works fine, the sound on my videoclip imported to modul8 can be heard on external loudspeakers. but when i try to use the "sound in" effect in modul8 i don´t get any reaction.
    in the system prefs / audio in i do see the audio level. (from m-audio i go into my mixer, from there back into the input of the interface)
    sound in is set to full, the effect is adjusted to the layer, i also restarted modul8.
    i´m in pain. anyone an idea????
  • anomad
    Re: m-audio output works, but no sound in!!
    by anomad » Mon Jul 23, 2012 7:22 pm
    . make sure to turn up the 'SOUND LEVEL' IN knob in the bottom right corner of the main modul8 window.
    -james
    (a nomad. )
  • t-xis
    by t-xis » Mon Jul 23, 2012 10:47 pm
    thank´s but it´s been turned on the highest level already... would be a nice solution ;)
    tdog
    by tdog » Tue Jul 24, 2012 9:13 am
    levels showing in sound analysis?
    tdog
    By any means necessary....
    orion
    by orion » Tue Jul 24, 2012 11:51 am
    you also have to make sure you set up your sound card before you launch m8.
  • t-xis
    by t-xis » Sun Aug 05, 2012 5:41 pm
    hey there,
    finally IT WORKS!!!
    i got a new interface: the scarlett 2i2 focusrite
    if i want to play the audio from my laptop and use modul8 on the same one soundflower helps. in the audio prefs i set input and output to soundflower
    if i want to use an external audio device i set the audio prefs input to scarlett 2i2 and the output to internal loudspeakers and so this is working finally too!
    maybe this is helpful to anyone.
    stef
