Spacial Scanner
  • awatku
    Spacial Scanner
    by awatku » Thu Aug 02, 2012 11:31 am
    have canon EOS 5D mark II and wanted to use spatial scanner,
    but the madmapper does not recognized my camera, however I tried it led to no result, I coonec the camera via USB cable,
    when I open the madmapper, the camera is not shown,
    but I use a sony video camera and connected it via firewire and it worked,
    does it need a special software or setting ?
    Re: Spacial Scanner
    by franz » Mon Aug 06, 2012 1:18 am
    you should be in manual mode, manual focus, speed 1/40
    you should have a sd card in the camera
    picture mode should be jpeg, S (no raw)
    you should use a ferrite usb cable
    if it's not recognized, restart the computer, restart madmapper,
    then restart the camera,
    plug the camera to the computer using usb
    go to the space scanner
    you should see your camera listed and have a preview on screen
