16-bit Pixel Type
  • impsnldavid
    16-bit Pixel Type
    by impsnldavid » Tue Aug 28, 2012 4:23 am
    Certain types of LED fixtures can operate in 8-bit or 16-bit modes, where when operating in 16-bit, each property (red, blue, green, white, intensity, etc.) occupies two DMX channels, a coarse and a fine. Whilst obviously when mapping from an 8-bit video source using 16-bit control is pointless, it would still be handy to have to option to specify this as a pixel type. There are lots of situations where it is impractical to change the operating mode of the fixture (there may not be time, the fixture may be rigged and inaccessible, or it may be being used by other systems) so the ability to address fixtures operating in this mode from MadMapper is needed.
    Re: 16-bit Pixel Type
    by franz » Tue Aug 28, 2012 5:36 pm
    good remark.
    can you name any fixture that uses 16bit mode for RGB/Luminosity ?
    (it would be handy to get one for testing)
    at the moment, you can still use an offset in-between luma values, so that only the MSB (most significant bit) will be sent through artnet, hence reducing your 16bit value to half precision.
  • impsnldavid
    by impsnldavid » Thu Aug 30, 2012 5:41 am
    The PixelRange SmartLine fixtures have a 16-bit mode, http://www.pixelrange.com/pixelrange/index.php?id=3.
    firionicable
    by firionicable » Thu Oct 18, 2012 6:45 am
    Does this works best with garage Cube?
    by mad-matt » Mon Oct 09, 2017 7:30 pm
    If you use materials on fixtures you are working with a floating point source (not a RGB 8 bits per component source, like images, movies or Syphon textures - they are 8 bpc in most cases but MadMapper supports other formats) - so you can have more than 8 bits precision in your source !
    by mad-matt » Tue Nov 27, 2018 5:24 pm
    Do I need to setup or configure the MM fixture or light fixture itself in any special way to control them using such floating point values?
    No. Inside a GPU shader we're always working with floating point.
    Cheers!
    by mad-matt » Wed Dec 05, 2018 10:12 am
    In MadMapper fixture editor you can make 16 bits channels for red, green, blue, luminosity, or channels controlled with slider etc.
    So the 16 bits channel getting the RED value of the shader can be used for a a 16 bits PAN control, the green for tilt etc. If you want to control the pan & tilt with a material shader & the color with another material you can split your fixture in two and set some channels to "unused" in each fixture definition. Then you patch both at the same address. A bit tricky but it opens many possibilities
