MadLAb Kinect Masker Flicker
    Boxcutter
    by Boxcutter » Fri Sep 14, 2012 12:54 pm
    I'm using Madlab kinect masker and the first few times it worked fine. Now when I launch it, the blue tinted side (right), flickers, like a light bulb going in and out. Then when I launch MadMapper, same problem. Filckering. My Kinect works fine with other programs, i.e. synapse, Tuiokinect, but only with Madlab Kinect masker does it flicker. I tried a new power source for kinect, no luck. Anyone experience this problem? Or no why this is happening, and how to fix?
    Tim H
    2010 MacBookPro
    OSX 10.6.8 Snow Leopard
    2.8Ghz intel core i7
    8 G RAM SS drive
  • Jaysonaut
    Re: MadLAb Kinect Masker Flicker
    by Jaysonaut » Fri Sep 21, 2012 8:51 pm
    I`ve got almost the same setup, and almost the same problems - but get no input at all! Neither synapse nor masker. Looking for help, too.
  • wiger123
    by wiger123 » Sat Sep 29, 2012 1:23 pm
    Nice sharing
    wiger
    Boxcutter
    by Boxcutter » Tue May 07, 2013 11:30 pm
    ? wiger123 ?
    Tim Hix
    Don't Try
