Three-Screen Installation / configuration hardware+software
  • Njo2012
    by Njo2012 » Sun Sep 23, 2012 7:35 pm
    Hello
    I'm a new user of M8.
    I need to launch 3 different videos from my MacBookPro 15' simultaneously which will be projected on three screens.
    As far as I understood I need to use Module 8 and Matrox Triplehead2Go Graphics Expansion Module.
    I have a miniDP output on my Mac.
    Would this configuration be enough for my video installation ?
    Thanks !
    Nath
  • Chadcona
    Re: Three-Screen Installation / configuration hardware+softw
    by Chadcona » Thu Dec 13, 2012 1:07 am
    Hey Nath, I'm new here too but i've been pretty much running that exact setup. Only difference is i have a macbookpro 13' with the mini display port, which I think is the same as thunderbolt? Either way I use modul8 to output 3 different videos, just change my display settings to fit 3 wide layers in, be it 2400x600 (800x600)x3 wide or whatever output you need, i use the triple head 2 go with a min dp to vga adapter! Then use mad mapper for endless possibilities, works awesome!
