RE: 1.3 Beta
  • stphntylr
    RE: 1.3 Beta
    by stphntylr » Tue Oct 02, 2012 9:34 pm
    It seems that when I create DMX fixtures in the 1.3 beta, they work fine. Until I switch presets at which point the fixtures go "dark". No more output, and even the preview shows nothing. If I duplicate the fixture it comes back to life. This is not due to opacity or RGB values as the only thing that has to be done to fix it is to recreate the fixture.
    Anyone else messing around with the beta experience this?
    On a side note, the pixel mapping is an amazing addition!
    Re: RE: 1.3 Beta
    by ilan » Wed Oct 03, 2012 11:05 am
    This is officially a bug report so if you can send it to support that will be super helpful to us.
  • stphntylr
    Re: RE: 1.3 Beta
    by stphntylr » Wed Oct 03, 2012 3:32 pm
    Absolutely. Wasn't sure which route to go.
    Va.Ha.jr
    Re: RE: 1.3 Beta
    by Va.Ha.jr » Sat Oct 06, 2012 6:39 am
    I bought ENTTEC DMX USB PRO. I plugged it in and did not find it in the MadLight ver.1.3 preferences dmx output. Will it work in the final version MadLight or dmx output work only via ArtNet?
  • stphntylr
    Re: RE: 1.3 Beta
    by stphntylr » Sat Oct 06, 2012 8:43 am
    You might be able to use the LCompanion app from synthe fx to turn your USB into artnet. I know it will for the iPad app. Not sure how it might work on the same machine.
    Va.Ha.jr
    Re: RE: 1.3 Beta
    by Va.Ha.jr » Sat Oct 06, 2012 1:38 pm
    Thanks for the reply. I will try. Maybe there are other options?
Users browsing this forum: Baidu [Spider] and 9 guests
