MadMapper Syphon output distorts masks
  • kleurbleur
    by kleurbleur » Mon Oct 15, 2012 2:13 am
    Didn't know but was pleasantly surprised to find a Syphon output from MadMapper in my trial of Millumin!
    Since I wanted to keep Millumin clean, and also find their mask tool less then efficient as it is (changes size when the syphon source changes), I thought I'd give MadMapper a try.
    This is the result:
    Re: MadMapper Syphon output distorts masks
    by ilan » Mon Oct 15, 2012 11:01 am
    If you use the Syphon Client test application do you get the same result?
    If you don't have it you can download it from the Syphon page:
    http://syphon.v002.info/
  • kleurbleur
    by kleurbleur » Mon Oct 15, 2012 11:34 am
    Hmm, seems to be that the Syphon website is down. Got the apps from googlecode now.
    The masking problem is not visible in the Simple Client, although the Simple Client isn't displaying the correct resolution from MadMapper. It does for Millumin though.
    Sending an email to Philippe about the masking bug, meanwhile, is it on purpose that MadMapper is sending this res?
    by ilan » Mon Oct 15, 2012 12:36 pm
    You can set the res size in the general output settings (the tab on the far right within the utility panel).
    What size are you trying exactly so I can test this out on my end?
  • kleurbleur
    by kleurbleur » Mon Oct 15, 2012 2:17 pm
    As you can see in the screenshot above, I tried 1920x1080. I wasn't connected to a projector/external screen yet, don't know if that makes any difference?
    by ilan » Mon Oct 15, 2012 4:12 pm
    Just checked it and also tested it using Resolume Arena 4. The mask is not a problem but it is strange that the output is smaller than what is specified. I will look into this asap. Thanks.
    Anome
    by Anome » Tue Oct 16, 2012 4:11 pm
    I confirm : MadMapper Syphon server cannot go above 800 pixels wide.
    The problem can be seen in the Simple Client app or directly in Millumin (if you didn't normalized your layer).
    Apparently, above 800 pixels wide, MadMapper resize the Syphon server to 800 pixels and fix the ratio.
    Best,
    Philippe
    Image . . . . Image
    by ilan » Tue Oct 16, 2012 4:32 pm
    Hello Philippe,
    Thanks for the notification.
    I saw this the other day and reported it to our team.
    Congrats on Millumin.
    Best,
    Ilan
    by franz » Wed Oct 17, 2012 12:05 pm
    MadMapper's Syphon output is dependent on the viewer resolution.
    Connect madmapper to a projector outputting 1280*1024, your syphon output will be the same.
    by ilan » Wed Oct 17, 2012 12:44 pm
    This will be corrected in the next release. Changing the setting will change the Syphon output size.
  • kleurbleur
    by kleurbleur » Mon Oct 29, 2012 11:22 pm
    Any timeframe when this release will be? Kind of need it within the next 2 weeks. :roll:
