Spacial scanner multiple outputs
  • mradamyoung
    by mradamyoung » Mon Oct 15, 2012 3:05 pm
    There are a couple of things that I am struggling to work out and wondered if anyone else has found this possible.
    1. 95% of the time we use Catalyst as the media server of choice on all projects. Normally the out put is attached to a Datapathx4 allowing 4 HD outputs. (We have managed to get the Catalyst output to go via syphon into MadMapper)
    It works with Catalyst outputting one large output; 3840*2160... and then each out put on the Datapath looks at a specific 1920*1080 region of this display. Very similar to a triple or dual head. You then set 'Mixes' inside the catalyst to control what comes out of which output.
    Is there a way to send the special scanner to a specific region on a large output? so that all four outputs of the datapathx4 can be spatially scanned separately? So...
    'spacial scan 1' would be Top:left 0;0 Width*Height 1920*1080.
    'spacial scan 2' would be Top:left 0;1921 Width*Height 1920*1080.
    etc.
    Is this possible?
    2. If question 1 is possible... Is there a way to put a soft edge on certain edges of screens... so that two projectors can be soft edge blended.
    Any light you can shed on this would be amazing.
    Thank you.
Users browsing this forum: Baidu [Spider] and 27 guests
