Export output as Transparent PNG without layer info.
    lotech
    by lotech » Sun Oct 21, 2012 12:56 am
    It would be good if the Export Output option would allow for a PNG with transparency (or a pdf with separated layers).
    Currently the output makes a flattened image with layer names and borders which is mostly useless.
    If MM exported a PNG with transparency we could quickly and easily export the png to our mixers (Blackmagic 1M/E) frame store as a backup mask/key. I haven't had MM crash but if something did go wrong it would be good to switch to a non mapped input with a DSK (down stream key) of the mask.
