MadLight with Conventionals
  • joeladria
    by joeladria » Wed Nov 07, 2012 5:47 am
    I'm using MadMapper in our theatre, and would like to use the MadLight features using an array of conventional fresnels with R/G/B gels in them.
    Is there a way to accomplish this using MadLight? I tried to create a fixture for it, but there does not seem to be individual "R" pixel types that would be required, other than the "L" pixel type. Could this be a future addition?
    Thanks.
    Re: MadLight with Conventionals
    by franz » Wed Nov 07, 2012 11:53 am
    L is for brightness.
    If you're using gels, you would typically send just Brightness value, since the color comes from the gel.
  • joeladria
    by joeladria » Sat Nov 10, 2012 3:53 am
    Yes, I realize the L would work for strictly black/white mapping, however MadLight only outputs luminosity in that case. There is no way of sending the amount of red on a particular area to a particular address without contiguous groupings of 3 RGB, etc.
  • Maisch
    by Maisch » Wed Dec 19, 2012 10:00 pm
    does it work if you dimmer per says has start DMX 1. with par can with a red gel at # 1, the next adress is 2 with a Green gel and the third lamp on the DMX line is a blue. If you then create a RGB fixture with thre channels starting at DMX Ch 1. Would the Red Parkann react when you only send red output? or do you need to make a single light fixture for each DMX adress?
  • joeladria
    by joeladria » Thu Dec 20, 2012 8:37 am
    Yes, if the lighting fixtures were contiguously numbered, this would not be an issue. Unfortunately, in our theatre we don't always have the luxury of continuous numbering, given that it is dimmer-per-circuit. Thus, it would great to have individual control over each color of pixel.
Users browsing this forum: Baidu [Spider] and 13 guests
