MadLight Tutorial
  • ziogas
    MadLight Tutorial
    by ziogas » Thu Nov 08, 2012 9:10 am
    Please, if it is possible can you make a short, clear tutorial on MadLight? There is too much questions about it.
    Maybe someone can answer main one: what kind of light can you control via MadLight? Can you control the light heads like Robin Spot or Clay Paki? Or is there any possibility to plug GrandMa into MadMapper and control both video and lights?
    Re: MadLight Tutorial
    by franz » Thu Nov 08, 2012 12:43 pm
    MadLight sends Artnet signals.
    With the proper card (such as Enttec OpenDMX), you can convert Artnet signal to DMX signals, which are used to control lighting equipment.
    Think of DMX as the equivalent of MIDI, but for lights.
    So any device that is DMX compliant will work with MadMapper.
    Controlling moving light (such as clay Paky) is theoretically possible, however, you'll be driving PAN TILT (= movement) with pixel data, which might be awkward in some situations.
    A tutorial is coming on that subject.
    controlling MAdMapper from a GrandMa was already possible - since version 1.1-, as MadMapper accepts DMX control data as an input
  • scaryxpuppy
    by scaryxpuppy » Thu Nov 08, 2012 12:46 pm
    Do you recommend any cards that have multiple DMX universe outputs?
    The ENTTEC PRO seems to only have 1 DMX Out, and I can foresee the 512 channels of 1 universe soon being "eaten up" as I get pixel creative.
    A 4 universe card would be great
    Any ideas
    PHIL
  • ziogas
    by ziogas » Thu Nov 08, 2012 12:50 pm
    Than you!
    So thats exactly what I meant: that it can be awkward to control moving light, and really its useful only for fixture lights.
    But still I dont really understand how to manage that via MadMapper so waiting for the proper tutorial!
    Thanks guys!
  • ziogas
    by ziogas » Thu Nov 08, 2012 12:51 pm
    Phil, you can use DMX splitter, any of those will do.
    by franz » Thu Nov 08, 2012 12:52 pm
    the Enttec DATAGATE MK2 has 8 outputs, but is much more expensive.
    Depending on the number of output you "need", you can always get multiple Enttec ODE and plug them all to a router.
  • scaryxpuppy
    by scaryxpuppy » Thu Nov 08, 2012 12:56 pm
    Hi Ziogas,
    The DMX splitting still limits me to just 512 Channels....
    Franz - thanks for that - will checkout the 8 way ArtNet
    (or as you say just but new single way ones as and when I need expansion)
    Thanks guys
    PHIL
    colabs
    by colabs » Tue Nov 13, 2012 7:50 pm
    Yes, a tutorial on Madlight use is going to be really helpful, mainly on getting the Artnet side of things up and running. Also, a running list of tested and supported Artnet/DMX interfaces would be very helpful.
    This is a game changer to be sure. Not that Pixel mapping is a new thing, but this really lowers the entry point and ease of use. Looking forward to seeing what people make with this.
    Anthony Diehl
    by franz » Wed Nov 14, 2012 12:06 am
    any artnet node should work out of the box.
    it has currently been tested on a Enttec ODE (Open DMX).
    The Enttec USB DMX Pro will be supported in MadMApper 1.4 final or 1.5 beta (just not yet).
  • ziogas
    by ziogas » Tue Dec 18, 2012 8:45 pm
    Still waiting!
    by franz » Wed Dec 19, 2012 6:57 pm
    We are finalizing a very detailed tutorial and reference file, but due to the holiday xmas season, it won't be ready before mid/end january.
    colabs
    by colabs » Wed Dec 19, 2012 7:05 pm
    Thanks Franz. Looking forward to this.
    Anthony Diehl
  • martyw79
    by martyw79 » Thu May 09, 2013 4:25 pm
    Did this 'detailed tutorial and reference file' ever get released?
    by ilan » Sat May 11, 2013 12:52 pm
  • martyw79
    by martyw79 » Tue May 14, 2013 1:33 am
    Excellent, thanks Ilan.
