Zoom in on a surface using SHORTCUT
  • scaryxpuppy
    by scaryxpuppy » Mon Nov 12, 2012 3:30 pm
    Am currently re-designing an application for MADMAPPER CONTROL, using OSC, now that in the newest BETA version there is the option to TAB through CORNER PINS - this allows for very fast editing "up close and personal" to the screen surfaces.
    However, I as having a problem when it comes to ZOOMING in on a selected surface.
    The shortcut CMD+PLUS only zooms the view in as far as the actual composition canvas !
    However, if you use the actual PLUS and MINUS buttons above the output preview window, you can zoom in as much as needed.
    This ability to ZOOM right in is very useful fro precise pixel adjustment.
    Anyone got any ideas, or is it just in the new BETA version? (unfortunately my current laptop only has the BETA version on so i can't check older version history)
    Many thanks
    PHIL
    Re: Zoom in on a surface using SHORTCUT
    by franz » Tue Nov 13, 2012 12:51 pm
    in version 1.4:
    z zoom to selected surface
    CMD + zoom in (no limit)
    CMD - zoom out
    CMD = zoom stage extends
  • scaryxpuppy
    by scaryxpuppy » Tue Nov 13, 2012 3:17 pm
    Thanks Franz!!
    Was a case of OSCULATOR seeing CMD+PLUS without the SHIFT so it was just zooming to fit !
    All resolved
    Many thanks, and thanks for a great update 1.3 and 1.4 really good big changes
    Thanks again
    PHIL
