Madlight: reverse RGB values
  • menoTV
    by menoTV » Tue Nov 27, 2012 6:50 pm
    Anyone got a cunning way of reversing the RGB values in madlight? MY RGB strips are in fact ordered BGR, so my Red and Blue values are switched.
    Any way round this?
    BTW i believer this is quite common... if there were a 'BGR' pixel option along with RGB, RGBL etc, then all possible arrangements of R, G anfd B would be no problem to deal with/
    Cheers.
  • menoTV
    Re: Madlight: reverse RGB values
    by menoTV » Mon Dec 03, 2012 5:56 pm
    For anyone else with the same problem... i have made a workaround using quartz composer, as you will see it inverts the red and green channels of the image, and sends both the inverted and normal images to madmapper using siphon.
    I dont seem to be allowed to upload a qtz file... email me if you need it and i'll email it back. visuals {at} meno -dot- tv
    by franz » Wed Jan 16, 2013 11:29 pm
    we've added BGR and BRG support in MadMapper 1.4 final version.
  • joanpc
    by joanpc » Sun Feb 10, 2013 6:38 pm
    franz wrote:we've added BGR and BRG support in MadMapper 1.4 final version.
    Opps, whe bought a rgb stripe with the GRB configuration, It will be awesome if you can add that option too. An advanced fixture editor where you'll be able to specify a channel for each color will be awesome.
    Thanks for your great job guys!
    by franz » Wed Feb 20, 2013 1:55 pm
    planned for 1.5
  • Mackeroney
    by Mackeroney » Mon Mar 18, 2013 8:21 am
    I, too, need the GRB value set so now I'm eagerly awaitng 1.5! so far madlight has been one of the best additions ever! You guys are seriously taking this software suite to a whole new level.
    You is what you is, you ain't want you ain't.
  • readydestroy
    by readydestroy » Thu Apr 04, 2013 3:17 am
    I also need GRB value set! 1.5 can't come fast enough. Blending video with LEDs is great.
  • amros123
    by amros123 » Fri Jan 17, 2014 5:04 pm
    readydestroy wrote:Blending video with LEDs is great.
    that's true
    by franz » Sat Jan 18, 2014 12:36 pm
    with 1.6 (beta available on yourspace),
    you can make ANY combination you want.
