artnet loses signal
  • LOTUSLUMINA
    artnet loses signal
    by LOTUSLUMINA » Thu Dec 06, 2012 3:38 pm
    We work with madmapper 1.3 with artnet ...
    Unfortunately MM loses the connection to Artnetcontroller at switching from preset's Different?
    You must then select the new connection in the preferences?
    is this normal?
    We work with OXO Netbox8, everything works great except the described error ....?
    Can you help us further here?
    sorry for my bad english ... =)
    LG dominik
    Re: artnet loses signal
    by franz » Thu Dec 06, 2012 4:39 pm
    hi,
    no this is not a normal behavior.
    MadMapper is broadcasting Artnet messages through the network.
    Once an ethernet cable is plugged into you Mac, and the address is set correctly, MadMapper doesn't really care if there's a box at the other end of the network.
    Are you connected directly between your Mac and your OXO ? Is there a hub/switch in between ?
    Are there other devices into your network ?
    Try to plug it as directly as possible.
    If the problem persists, please contact the support by email.
    suuport[at]garagecube.com
    they'll help you solve the problem.
  • LOTUSLUMINA
    by LOTUSLUMINA » Fri Dec 07, 2012 3:24 pm
    Thanks for your response!
    mac is connected directly to the OXO!
    do pass by several test's, and tell me then again with you ...
    Thank you
  • alison3492
    by alison3492 » Fri Jan 02, 2015 11:23 am
    randomly googled nodes and found this other usb to dmx converter. says you can run up to 8 of them. does this do the same thing as the enttec?
    by mad-matt » Mon Jan 12, 2015 7:43 pm
    I never tested it but yes it's an ArtNet->DMX node, so MM will send ArtNet over the network and this device will send it to its DMX output connections.
  • Xaver2k
    by Xaver2k » Thu Jan 15, 2015 9:54 am
    if you want to use more than 1 controller, i recommend you to use an ArtNet->DMX node! it´s more stable and easier to use (at least for me).
    did we really answered to an 2 year old post?? :? i hope it´s still usefull for somebody ^^
