Low Res Source Mapping + Arrow Key Bug
  • kleurbleur
    by kleurbleur » Thu Dec 13, 2012 10:25 pm
    Hi MadMapPeeps,
    I'm working on a very low res 8x7 pixel syphon image so it could be that I'm working on rare circumstances.
    Two bug reports:
    1. When I try to move a 1x1 pixel square from the source by mouse it only can grab either top left corner or the lowerleft corner of the quad.
    2. If I then try to move a quad in the preview with the arrow keys the quad only goes one way, often to the lower left corner. It doesnt matter which arrow key I press. If I click somewhere and try again it works, although sometimes I have to do this 3 times in a row.
    Re: Low Res Source Mapping + Arrow Key Bug
    by ilan » Fri Dec 14, 2012 11:21 am
    This is a bug report. Please send it to support so we can make a proper record of it.
    Thanks in advance.
    by franz » Fri Dec 14, 2012 1:18 pm
    did you disable Snapping ?
    since your image size is very small, it might be under the snapping radius,
    which would cause problematic behaviour.
