3D Projection
  • manitonga
    3D Projection
    by manitonga » Tue Dec 18, 2012 12:10 am
    It is possible to map with a 3D projector with MadMapper ?
  • MGrinder
    Re: 3D Projection
    by MGrinder » Tue Dec 18, 2012 3:23 am
    Active with shutter glasses or passive? My first reaction is no unless you were extremely careful, viewing angle and surface materials, processing, and warping would break the effect, and that's probably true for passive. But active, maybe? I'd be interested to hear the results if you try it.
    Re: 3D Projection
    by franz » Tue Dec 18, 2012 2:31 pm
    yes, it is possible.
    Depends on the tech. used.
    But it might get quite complicated at some point.
