Quartz composer crash
  • bfo.zam
    by bfo.zam » Thu Dec 20, 2012 6:09 am
    im using 2.6.4 version of modul8
    and because im one of those not secure enough to leave snow leopard just because of modul8
    im using quartz composer 4.0 (103.1)
    well the thing now is that every quartz composer i try to add into modul8 makes it crash....
    maybe is this new version...
    i remember i used quartz at the last modul8 release....
    do you thing something changed??
    im using quartz to personalize camera masks and give a small movement to them...
    if someone is familiar to this id like some tips
    Re: Quartz composer crash
    by The Midi Thief » Sat Dec 22, 2012 1:17 am
    I haven't noticed anything but I don't use QC so much in M8 because of the poor implementation. You mentioned that you are doing something with the camera in QC - make sure that you are not using the same camera in Modul8 since a camera can only be used by one application at the time. I haven't however noticed that something like that would cause M8 to crash. I were you I'd send my crash log to the Gragecube support.
  • bfo.zam
    by bfo.zam » Sun Dec 23, 2012 4:15 am
    as an update
    i installed the old version 261 and the quartz works like it should...but since is an old version i lost the syphon capability and the new things....
    the 264 and the new 265 dont work for me...
    i'll change the preferences inside md8 to see if is the camera thing...
