Need 16 Layers!
  • metacitizen
    Need 16 Layers!
    by metacitizen » Mon Dec 31, 2012 5:46 pm
    Is it possible to have 16 layers in Modul8, rather than only 10?
    I am video-mapping 16 different surfaces at once, and would like to be able to assign a different layer to each surface.
    The intention is then to midi-map each layer, being able to turn them on and off independently with a 16 pad controller.
    Any help or advice would be greatly appreciated!
    Best regards,
    M
  • metacitizen
    Re: Need 16 Layers!
    by metacitizen » Thu Jan 03, 2013 1:40 pm
    Does anybody know a way to achieve this?
    I need to have 16 pads on my midi controller turning on and off 16 different videos that are mapped to 16 different surfaces.
    Apparently there it is not possible to have 16 layers being used at once, what other method would you recommend?
    Thanks so much!!!
    M
  • anomad
    Re: Need 16 Layers!
    by anomad » Thu Jan 03, 2013 6:06 pm
  • metacitizen
    Re: Need 16 Layers!
    by metacitizen » Thu Jan 03, 2013 6:31 pm
    Hi anomad, thanks for your response.
    Yes, I am using Madmapper to map 16 loops to 16 surfaces via Modul8.
    The question is how to manage the 16 loops in Modul 8 at the same time, with the possibility of turning them ON and OFF independently.
    Any advice would be greatly appreciated!
    M
  • anomad
    Re: Need 16 Layers!
    by anomad » Thu Jan 03, 2013 9:06 pm
    . well... depending on your setup/requirements you might be able to combine two smaller videos that don't overlap in to once clip and use the crop free frame effect to show one, both or neither... however, if you're talking about 16 full sized clips - i don't think it can be done w/modul8.
    -james
    (a nomad. )
Users browsing this forum: Baidu [Spider] and 15 guests
