Video Capture
  • vincelicht
    Video Capture
    by vincelicht » Tue Jan 08, 2013 4:38 pm
    I know that the subject has already been treated but I still have a doubt ...
    Is it possible to import a live feed from an analogic cam with an acquisiton device on USB 3.0 port ?
    In brief, can I use something like this http://www.blackmagicdesign.com/products/videorecorder/ to import 3 analogic cameras in a Mac mini with 4 USB 3.0 ports ?
    Thank you for your help
    Vincent
    Valparaiiso
    Re: Video Capture
    by Valparaiiso » Wed Jan 16, 2013 11:38 pm
    No, you can't.
    This kind of stuff works only with BlackMagic Video Recorder, their software.
    It's explained on BMD site.
  • vincelicht
    Re: Video Capture
    by vincelicht » Thu Jan 17, 2013 12:16 pm
    Thanks for your answer valparaliso. So I finally decided to try to find a used mac pro and get PCI cards, it will be better I think.
  • najrock
    Re: Video Capture
    by najrock » Thu Jan 31, 2013 10:22 am
    I was looking into upgrading from my blackmagic junk...
    has anyone here used an external thunderbold pci card slot with the datapath capture cards?
