Artnet Question
  • Steamboy
    Artnet Question
    by Steamboy » Fri Jan 11, 2013 12:46 am
    I am testing madmapper (demo mode) to check if it fits my needs.
    I have an artnet led array I used to drive through a Dmxking box or OLA daemon. Both are configured in Artnet II so I am using my own subnet (192.168...).
    On the fixture DMX screen, I have Artnet Output/ Artnet not configured.
    I was wondering if configuration is automatic and if my problem is due to using my subnet (vs 10.10.....) ?
    Is-it possible to use DMX fixture on my subnet ?
    Thanks for your help,
    Regards,
    Christophe.
    deepvisual
    Re: Artnet Question
    by deepvisual » Fri Jan 11, 2013 10:59 am
    are you confusing artnet subnets with subnet mask?
  • Steamboy
    Re: Artnet Question
    by Steamboy » Fri Jan 11, 2013 11:47 am
    No, I am using unicast which is part of Artnet 2 I think.
    Regards,
    Christophe.
  • Steamboy
    Re: Artnet Question
    by Steamboy » Fri Jan 11, 2013 8:47 pm
    I did more investigation and the problem was coming from my universe configuration.
    Now, it was working.
    Regards,
    Christophe.
  • Steamboy
    Re: Artnet Question
    by Steamboy » Sat Jan 12, 2013 12:21 pm
    I setup my led array (46x10 - contiguous universes) using multiple fixtures. Everything seems correct, but I have some artifacts. Randomly, some fixtures blackout for a few seconds. I attached the screen capture.
    Capture d’écran 2013-01-12 à 11.12.44.png (123.48 KiB) Viewed 7953 times
    Any idea from where the problem could come from ?
    Regards,
    Christophe.
    Re: Artnet Question
    by franz » Mon Jan 14, 2013 12:05 am
    are you using MadMapper demo ?
    the demo randomly blacks out fixtures.
  • Steamboy
    Re: Artnet Question
    by Steamboy » Mon Jan 14, 2013 1:22 pm
    Yes I am using the demo version.
    Regards,
    Christophe.
    Re: Artnet Question
    by franz » Mon Jan 14, 2013 3:12 pm
    Sorry we should have said that more clearly when downloading the demo.
    Re: Artnet Question
    by ilan » Tue Jan 15, 2013 12:51 pm
    It's written on at the bottom of the specs page: http://www.madmapper.com/madmapper/specs/
