Does not save "Over the Quad" Mask state
  • 1000errors
    by 1000errors » Sat Jan 19, 2013 4:11 pm
    Whenever I set a mask to be "over the quad" after saving the project when I reopen it the mask reverts to back to being "inside the quad" and is therefor a smaller different shape.
    Please fix this, it is really annoying.
    Thanks very much in advance :)
    Olly aka 1000 Errors
    www.1000errors.com
    Re: Does not save "Over the Quad" Mask state
    by ilan » Sun Jan 20, 2013 1:58 pm
    I got your message on the support, and we have another report as well. We'll look into correcting this problem as soon as possible.
    Thank you for your diligence.
    by franz » Mon Mar 04, 2013 7:13 pm
    this problem is now corrected in MadMapper 1.4.2
    thanks for reporting this
  • CONTACT
    by CONTACT » Sun Mar 10, 2013 12:00 am
    hi there, i'm having a similar problem where the mask gets ignored by the quad completely.
    in other words, the mask is created inside the quad, but content is still visible inside the quad. restarting madmapper fixes the problem, but obviously i cannot do this mid show.
    this error occurred on both madmapper 1.4.1 and the latest 1.4.2. clean install of 1.4.2.
    i've just stopped using quad masking for my projects, but have a really big festival gig coming up next week where masks inside the quad will be needed and i want to make sure that I can use it for this show without issue.
    if you have any insight as to why this is happening, please let me know.
    thanks
    by franz » Sun Mar 10, 2013 3:34 pm
    just to be sure, I tried on my computer:
    - new file
    - create quad
    - create mask INSIDE the quad --> it's working OK
    - save file
    - quit MM
    - load file
    ---> Quad is Masked and the mask is INSIDE the quad
    So here it IS working properly, as expected.
    Send us a step by step to reproduce your problem, we'll fix it.
