Image quality should be set to jpeg only
  • bearit641
    by bearit641 » Sat Jan 26, 2013 11:28 am
    I have just bought an EOS 1100D to use the spacial scanner
    I am running Madmapper 1.4 on an iMac 2.66 i% with 16GB memory
    The camera is set to manual with a shutter speed of 1/40
    In the spacial scanner box Madmapper says...
    Canon Eos 1100D
    1920x1080
    There is NO preview
    When I click on capture I get the message
    " Image quality should be set to jpeg only (not RAW or JPEG+RAW)"...... I am pretty sure it IS only set to JPEG - setting S1
    I have tried this on FIVE macs now - it works on ONE perfectly..but not on ANY of the others..ranging from the iMac above to MBP and MBA and another iMac 21"
    The error log is below -but it has to be some conflicting software - the ONLY difference I can see on the face of it is that the one it does work on had Apature installed - all the others are in any state from fresh install to well used!
    Process: MadMapper [586]
    Path: /Applications/MadMapper.app/Contents/MacOS/MadMapper
    Identifier: com.garagecube.MadMapper
    Version: 1.4 [2079] (1.4.2079)
    Code Type: X86 (Native)
    Parent Process: launchd [172]
    User ID: 501
    Date/Time: 2013-01-25 15:20:19.625 +0000
    OS Version: Mac OS X 10.8.2 (12C60)
    Report Version: 10
    Interval Since Last Report: 324555 sec
    Crashes Since Last Report: 9
    Per-App Interval Since Last Report: 282 sec
    Per-App Crashes Since Last Report: 6
    Anonymous UUID: 7FF3EA2D-0565-F67E-48BF-825ABC7D72F9
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000080000020
    VM Regions Near 0x80000020:
    __LINKEDIT 000000000f5da000-000000000f5e3000 [ 36K] r--/rwx SM=COW /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
    __TEXT 000000008ed4a000-000000008f58c000 [ 8456K] r-x/rwx SM=COW /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    Application Specific Information:
    objc_msgSend() selector name: release
    Performing @selector(qtDispatcherToQAction:) from sender NSMenuItem 0x1c8cb30
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 libobjc.A.dylib 0x90e12a87 objc_msgSend + 23
    1 libobjc.A.dylib 0x90e15442 (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 490
    2 com.apple.CoreFoundation 0x929a2083 _CFAutoreleasePoolPop + 51
    3 com.apple.Foundation 0x99beec16 -[NSAutoreleasePool release] + 125
    4 com.canon.edsdk 0xb0034c07 CIccMan::SendPtpCommand(void*, tagEdsPassThrough*) + 961
    5 com.canon.edsdk 0xb002d170 CMacPtpInterface::SendCommandSelf(void*, SPtpParam*) + 120
    6 com.canon.edsdk 0xb002a822 CPtpInterface::DS_SetRemoteMode(void*, DS_REMOTE_MODE_T) + 156
    7 com.canon.edsdk 0xb001ea78 CPtpCamera::OpenSessionSelf() + 314
    8 com.canon.edsdk 0xb000e531 CEdsCamera::OpenSession(long) + 69
    9 com.canon.edsdk 0xb0003bd4 EdsOpenSession + 77
    10 com.garagecube.MadMapper 0x001885d5 0x1000 + 1603029
    11 com.garagecube.MadMapper 0x0018b80f 0x1000 + 1615887
    12 com.garagecube.MadMapper 0x001727b4 0x1000 + 1513396
    13 com.garagecube.MadMapper 0x00172a0f 0x1000 + 1513999
    14 com.garagecube.MadMapper 0x0001eb3a 0x1000 + 121658
    15 com.garagecube.MadMapper 0x0001b973 0x1000 + 108915
    16 com.garagecube.MadMapper 0x000b48c6 0x1000 + 735430
    17 com.garagecube.MadMapper 0x0017b04b 0x1000 + 1548363
    18 QtCore 0x010464a2 QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 934
    19 QtGui 0x0057d627 QAction::activate(QAction::ActionEvent) + 229
    20 QtGui 0x00532db5 0x501000 + 204213
    21 libobjc.A.dylib 0x90e2b5d3 -[NSObject performSelector:withObject:] + 70
    22 com.apple.AppKit 0x94ed6bd2 -[NSApplication sendAction:to:from:] + 436
    23 com.apple.AppKit 0x950133dc -[NSMenuItem _corePerformAction] + 529
    24 com.apple.AppKit 0x9501306b -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 163
    25 com.apple.AppKit 0x950126f4 -[NSMenu _performActionWithHighlightingForItemAtIndex:sendAccessibilityNotification:] + 79
    26 com.apple.AppKit 0x94cf32ba -[NSMenu performActionForItemAtIndex:] + 65
    27 com.apple.AppKit 0x94cf326f -[NSMenu _internalPerformActionForItemAtIndex:] + 45
    28 com.apple.AppKit 0x94cf323a -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 106
    29 com.apple.AppKit 0x94cf30b9 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 162
    30 com.apple.AppKit 0x9500b7ce NSSLMMenuEventHandler + 454
    31 com.apple.HIToolbox 0x97a03b6b _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
    32 com.apple.HIToolbox 0x9788b594 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
    33 com.apple.HIToolbox 0x9788a980 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
    34 com.apple.HIToolbox 0x9789e855 SendEventToEventTarget + 88
    35 com.apple.HIToolbox 0x97a03a1a SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 498
    36 com.apple.HIToolbox 0x9787ab84 SendMenuCommandWithContextAndModifiers + 70
    37 com.apple.HIToolbox 0x9787ab31 SendMenuItemSelectedEvent + 268
    38 com.apple.HIToolbox 0x9787a9b6 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 134
    39 com.apple.HIToolbox 0x97a5002e MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 623
    40 com.apple.HIToolbox 0x9785b332 _HandleMenuSelection2 + 633
    41 com.apple.HIToolbox 0x9785b0af _HandleMenuSelection + 53
    42 com.apple.AppKit 0x94ec445a _NSHandleCarbonMenuEvent + 309
    43 com.apple.AppKit 0x94deb0df _DPSNextEvent + 2425
    44 com.apple.AppKit 0x94dea26c -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
    45 com.apple.AppKit 0x94de06cc -[NSApplication run] + 855
    46 QtGui 0x0053c12a 0x501000 + 241962
    47 QtCore 0x01030c63 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 337
    48 QtCore 0x01033cbd QCoreApplication::exec() + 179
    49 com.garagecube.MadMapper 0x001738b3 0x1000 + 1517747
    50 com.garagecube.MadMapper 0x0000a2b5 0x1000 + 37557
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0 libsystem_kernel.dylib 0x98d359ae kevent + 10
    1 libdispatch.dylib 0x92523c71 _dispatch_mgr_invoke + 993
    2 libdispatch.dylib 0x925237a9 _dispatch_mgr_thread + 53
    Thread 2:
    0 libsystem_kernel.dylib 0x98d348e2 __psynch_cvwait + 10
    1 libsystem_c.dylib 0x90b93289 _pthread_cond_wait + 938
    2 libsystem_c.dylib 0x90c20b30 pthread_cond_timedwait + 47
    3 QtCore 0x00f4f671 0xf32000 + 120433
    4 QtCore 0x00f4f358 QWaitCondition::wait(QMutex*, unsigned long) + 118
    5 QtCore 0x00f44fc9 0xf32000 + 77769
    6 QtCore 0x00f4eb54 0xf32000 + 117588
    7 libsystem_c.dylib 0x90b8e557 _pthread_start + 344
    8 libsystem_c.dylib 0x90b78cee thread_start + 34
    Thread 3:
    0 libsystem_kernel.dylib 0x98d327d2 mach_msg_trap + 10
    1 libsystem_kernel.dylib 0x98d31cb0 mach_msg + 68
    2 com.apple.audio.midi.CoreMIDI 0x0035a22d XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
    3 com.apple.audio.midi.CoreMIDI 0x00377ae0 MIDIProcess::RunMIDIInThread() + 144
    4 com.apple.audio.midi.CoreMIDI 0x0037dc48 MIDIProcess::MIDIInPortThread::Run() + 24
    5 com.apple.audio.midi.CoreMIDI 0x0035b805 XThread::RunHelper(void*) + 17
    6 com.apple.audio.midi.CoreMIDI 0x0035b2ee CAPThread::Entry(CAPThread*) + 196
    Thread 4:
    0 libsystem_kernel.dylib 0x98d350ee __workq_kernreturn + 10
    1 libsystem_c.dylib 0x90b9104c _pthread_workq_return + 45
    2 libsystem_c.dylib 0x90b90e19 _pthread_wqthread + 448
    3 libsystem_c.dylib 0x90b78cca start_wqthread + 30
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    2 com.apple.CoreFoundation 0x929a1599 __CFRunLoopServiceMachPort + 185
    3 com.apple.CoreFoundation 0x929a6f7f __CFRunLoopRun + 1247
    4 com.apple.CoreFoundation 0x929a663a CFRunLoopRunSpecific + 378
    5 com.apple.CoreFoundation 0x929a64ab CFRunLoopRunInMode + 123
    6 com.apple.CoreMediaIO 0x95bd139f CMIO::DAL::RunLoop::OwnThread(void*) + 151
    7 com.apple.CoreMediaIO 0x95bc8938 CAPThread::Entry(CAPThread*) + 176
    8 libsystem_c.dylib 0x90b8e557 _pthread_start + 344
    9 libsystem_c.dylib 0x90b78cee thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x01d6cdd0 ebx: 0x99beeba7 ecx: 0x95636ec0 edx: 0x80000000
    edi: 0x0215c178 esi: 0x0215c000 ebp: 0xbfffda88 esp: 0xbfffd838
    ss: 0x00000023 efl: 0x00210202 eip: 0x90e12a87 cs: 0x0000001b
    ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
    cr2: 0x80000020
    Logical CPU: 0
    Binary Images:
    0x1000 - 0x2f3ff3 +com.garagecube.MadMapper (1.4 [2079] - 1.4.2079) <7724B979-02A9-3E78-8AD8-FD2BD27E3D7E> /Applications/MadMapper.app/Contents/MacOS/MadMapper
    0x331000 - 0x331ffb +GlimsLoaderMinimal.dylib (1) <D9C9F53F-1A94-4792-FED3-3F9AE6A98F91> /Library/Frameworks/GlimsAdditions.framework/Library/GlimsLoaderMinimal.dylib
    0x334000 - 0x342fff +info.v002.Syphon (1.0 - 1) <7F1B86D7-12F6-3DED-87D6-EFAD58D38178> /Applications/MadMapper.app/Contents/Frameworks/Syphon.framework/Versions/A/Syphon
    0x34c000 - 0x394ffb com.apple.audio.midi.CoreMIDI (1.9 - 78) <7AAE4076-36FA-37C1-9EAE-344F1C8F14D9> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x3b9000 - 0x464fff libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
    0x4a8000 - 0x4f1feb +QtSvg (4.7.1) <476406D7-73E6-32C0-8476-29DEBDF64E29> /Applications/MadMapper.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
    0x501000 - 0xe0aff3 +QtGui (4.7.1) <DE45D3A3-C102-356E-B28D-DDAA65AB10AA> /Applications/MadMapper.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
    0xf32000 - 0x1170ffb +QtCore (4.7.1) <415CC2B2-4DDA-3DB2-A923-24EAFEF3C34D> /Applications/MadMapper.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
    0x11b4000 - 0x157dfef +QtXmlPatterns (4.7.1) <1B684F56-3D79-3B37-8A1D-F06DBDAB4A39> /Applications/MadMapper.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/4/QtXmlPatterns
    0x15df000 - 0x16e0ff7 +QtNetwork (4.7.1) <199B3AD9-FE4F-3C6E-9BA8-C54EA32E2B5E> /Applications/MadMapper.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
    0x1704000 - 0x1760fef +QtXml (4.7.1) <938F4135-3BA3-3538-B97E-2735E054404A> /Applications/MadMapper.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
    0x1770000 - 0x1822fff +QtOpenGL (4.7.1) <E83FA6B9-B397-3738-8D44-4C5E111119BA> /Applications/MadMapper.app/Contents/Frameworks/QtOpenGL.framework/Versions/4/QtOpenGL
    0x1843000 - 0x1859ffc libexpat.1.dylib (12) <D4F1FD2B-F75A-322C-843E-113EF5F8EEAF> /usr/lib/libexpat.1.dylib
    0x1f22000 - 0x1f2fff3 com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
    0x1fc2000 - 0x1fc8fff +libqgif.dylib (0) <67AEB558-CEA8-39F3-9CF1-F3FC1186BFA6> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqgif.dylib
    0x1fcc000 - 0x1fd2ff7 +libqico.dylib (0) <16C90E44-4928-3651-9AE1-B70969CA35B8> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqico.dylib
    0x1fd6000 - 0x1fdbfff +libqsvg.dylib (0) <A2BCA4C3-17DD-3295-8465-D06066B57796> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqsvg.dylib
    0x34ab000 - 0x34dffef +libqjpeg.dylib (0) <0CBC0C57-EADB-3103-A326-7AF07BE72EDD> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqjpeg.dylib
    0x34e4000 - 0x352bfe7 +libqmng.dylib (0) <831AE607-36E8-38CD-AA95-BE45F0DA915E> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqmng.dylib
    0x3532000 - 0x353affc libcldcpuengine.dylib (2.1.19) <E5429AB3-FE28-3C0C-8942-686BB4191A9E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x3798000 - 0x37e7fff +libqtiff.dylib (0) <9A9FE019-95C0-34D4-9C2F-14276AA02AF0> /Applications/MadMapper.app/Contents/PlugIns/imageformats/libqtiff.dylib
    0x37f8000 - 0x37fafff libCoreFSCache.dylib (24.4) <A089ED2E-0156-3937-BE32-5BED76DF4066> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x87c4000 - 0x8882ff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x8cab000 - 0x8cb7ffb libGPUSupport.dylib (8.6.1) <FB98F9CE-31D0-321C-90FE-87D30294921B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
    0x8cbe000 - 0x8ceaffa GLRendererFloat (8.6.1) <D0348D87-ADBD-302B-95D0-FB3100C219BA> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x9fcc000 - 0xa158ff8 GLEngine (8.6.1) <2660B1D4-5783-3BED-8C05-F5A4C5A29715> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0xa18f000 - 0xa2e0ff7 libGLProgrammability.dylib (8.6.1) <E134D5DE-5A89-338A-A938-C7D80F272C9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0xa7dd000 - 0xa7ddffd +cl_kernels (???) <D041329C-1B7C-445B-96C8-35A3BFB9D186> cl_kernels
    0xb000000 - 0xb356ff3 com.apple.driver.AppleIntelHDGraphicsGLDriver (8.0.61 - 8.0.0) <79DF96F0-6564-396E-88B9-8B2A20CD14DA> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHDGraphicsGLDriver
    0xc4f4000 - 0xc4f9fff com.apple.audio.AppleHDAHALPlugIn (2.3.1 - 2.3.1f2) <58BDA15D-2B2D-3E77-BC8C-D14AB1E4AC4E> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0xcfe8000 - 0xcff1ffb +com.canon.DPPLibCom (3.11.0 - 3.11.0.2) <137E6106-6858-F50A-30DF-1806DD76BBF1> /Applications/MadMapper.app/Contents/Frameworks/EDSDK.framework/Versions/Current/DPPLibCom.bundle/Contents/MacOS/DPPLibCom
    0xda00000 - 0xda92ff7 unorm8_bgra.dylib (2.1.19) <A2C66114-F581-3D86-9BC9-9994156640AF> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0xdba4000 - 0xdbcdfff com.apple.cmio.DAL.VDC_4 (301.0 - 4147) <1EA9078C-E8C3-3694-8E22-27FB5676456F> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
    0xddd7000 - 0xdeeffef +com.canon.EdsImage (2.11.0.5 - 2.11.0.5) <2F43C206-61F2-FD29-BF43-61513B6D4613> /Applications/MadMapper.app/Contents/Frameworks/EDSDK.framework/Versions/Current/EdsImage.bundle/Contents/MacOS/EdsImage
    0xdf29000 - 0xf1f1fdf +com.canon.frameworks.DPP (3.11.30.4 - 3.11.30.4) <AA406056-6686-EDC0-E21B-4D8A0443F736> /Applications/MadMapper.app/Contents/Frameworks/DPP.framework/Versions/A/DPP
    0xf433000 - 0xf495ffb com.apple.CMIOQTUnits (301.0 - 4147) <779B58F9-AF45-3C15-AF25-FA76A8C14528> /System/Library/Frameworks/CoreMediaIO.framework/Resources/QuickTimeUnits/CMIOQTUnits.bundle/Contents/MacOS/CMIOQTUnits
    0xf4a5000 - 0xf4d6ffb com.apple.FWAVC (301.47 - 47) <CAC0D9D7-6B38-3A17-9200-4CC26E5DC39C> /System/Library/PrivateFrameworks/FWAVC.framework/Versions/A/FWAVC
    0xf4eb000 - 0xf525fff com.apple.QuickTimeFireWireDV.component (7.7.1 - 2599.13) <5FB303B9-3672-39AA-8CD6-E323CC0E41A8> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xf531000 - 0xf53afff com.apple.IOFWDVComponents (2.0.7 - 2.0.7) <B9264C9A-693B-3972-A3F1-7A324C147D61> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0xf545000 - 0xf56bfff com.apple.QuickTimeIIDCDigitizer (7.7.1 - 2599.13) <A9F3AA60-D2A5-37DA-84EC-0E05B5411263> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDigitizer
    0xf573000 - 0xf5c4ff7 com.apple.QuickTimeUSBVDCDigitizer (2.7.7 - 2.7.7) <9CA9E528-333D-35AF-804D-4C6F9544C2F9> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents/MacOS/QuickTimeUSBVDCDigitizer
    0xf5ce000 - 0xf5d8ffb com.apple.iokit.IOUSBLib (5.2.5 - 5.2.5) <E0E03D63-CF3D-3C34-8FE0-5E92CF648DB4> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
    0x8ed4a000 - 0x8f58bffb com.apple.GeForceGLDriver (8.0.61 - 8.0.0) <36946D7B-4FF7-34CC-B6FE-D6F48406A60F> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x8fe15000 - 0x8fe47e57 dyld (210.2.3) <23516BE4-29BE-350C-91C9-F36E7999F0F1> /usr/lib/dyld
    0x90007000 - 0x9000effe com.apple.agl (3.2.1 - AGL-3.2.1) <8E0411D3-19F7-30E1-92A2-337F7F0EBCDA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x900dd000 - 0x90126ff7 com.apple.framework.CoreWLAN (3.0.1 - 301.11) <ABA6A926-34C2-3C09-AD9F-A87A8A35536A> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x90127000 - 0x903a3ff7 com.apple.QuickTime (7.7.1 - 2599.13) <FE609160-E1EF-341D-9B6A-205D3E03A4D2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x903a4000 - 0x907c1fff FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
    0x907c2000 - 0x90847ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x90848000 - 0x90995ffb com.apple.CFNetwork (596.2.3 - 596.2.3) <1221EF86-659B-3136-AB57-0CC6B130CDA2> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x909aa000 - 0x90a0eff3 libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
    0x90a0f000 - 0x90a21fff libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
    0x90a22000 - 0x90a88fff com.apple.print.framework.PrintCore (8.1 - 387.1) <F8CF762B-B707-3021-958F-BB8D33DB3576> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x90a89000 - 0x90b33fff com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x90b78000 - 0x90c35feb libsystem_c.dylib (825.25) <B1F6916A-F558-38B5-A18C-D9733625FDC9> /usr/lib/system/libsystem_c.dylib
    0x90c36000 - 0x90c38fff libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
    0x90c39000 - 0x90c45ff7 com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x90cde000 - 0x90ce2ff7 libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
    0x90ce3000 - 0x90e01ff7 com.apple.MediaControlSender (1.4.5 - 145.3) <E0931EE7-4ACA-3538-9658-B9B2AC1E6A80> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
    0x90e0d000 - 0x90f1a057 libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
    0x90f1b000 - 0x912d3ffa libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x915c0000 - 0x915c3ff7 com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x915c4000 - 0x915c8fff com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x915c9000 - 0x915eeffb com.apple.framework.familycontrols (4.1 - 410) <5A8504E7-D95D-3101-8E20-38EADE8DEAE1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x915ef000 - 0x91767ff5 com.apple.QuartzCore (1.8 - 304.0) <0B0EC55A-9084-3E28-9A84-1813CE3FAA9B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x91768000 - 0x917e2ff7 com.apple.securityfoundation (6.0 - 55115.4) <A959B2F5-9D9D-3C93-A62A-7399594CF238> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x917e3000 - 0x917e9ffc libCGXCoreImage.A.dylib (324.6) <D75B1309-D224-344F-A28F-2B552859DDFC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    0x917ea000 - 0x91807ff7 libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
    0x91808000 - 0x91865fff com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x91866000 - 0x91876ff2 com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91877000 - 0x918dfff7 com.apple.framework.IOKit (2.0 - 755.18.10) <9A80E97E-544F-3A45-916D-6DB7ED217E33> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x918ec000 - 0x918edfff libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
    0x918ee000 - 0x918f1fff com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x91905000 - 0x919b9fff com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x919ba000 - 0x919bafff libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
    0x919bb000 - 0x919beff9 libCGXType.A.dylib (324.6) <3004616B-51F6-3B9D-8B85-DCCA3DF9BC10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x919bf000 - 0x91a18fff com.apple.QuickLookFramework (4.0 - 555.4) <96911441-FDD4-3B68-9E0C-51BA11A97C2E> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x91a19000 - 0x91a5aff7 com.apple.framework.CoreWiFi (1.0 - 100.10) <944B3FAE-F901-3276-A676-9D52295DA817> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x91a5b000 - 0x91a64ff3 com.apple.DisplayServicesFW (2.6.1 - 353) <50D0BBF0-F911-380F-B470-E59B5E48E520> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x91a65000 - 0x91ab3ff3 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91ab4000 - 0x91abafff libGFXShared.dylib (8.6.1) <E32A7266-FCDD-352C-9C2A-8939265974AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x91abb000 - 0x91b14ff7 com.apple.ImageCaptureCore (5.0.1 - 5.0.1) <541529F7-063E-370B-9EB2-DF5BE39073E6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x91b15000 - 0x91b23fff libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
    0x91b24000 - 0x91de4fff com.apple.security (7.0 - 55179.1) <CB470E48-621B-34D9-9E78-8B773358CB6B> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x91de5000 - 0x91e16fff com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x91e17000 - 0x92259fff com.apple.CoreGraphics (1.600.0 - 324.6) <66556166-F9A7-3EEC-A562-46061C7A79E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x9225a000 - 0x9225dff3 com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x9225e000 - 0x92280fff libc++abi.dylib (24.4) <06479DA4-BC23-34B6-BAFC-A885814261D0> /usr/lib/libc++abi.dylib
    0x92281000 - 0x922dbfff com.apple.Symbolication (1.3 - 93) <684ECF0D-D416-3DF8-8B5B-3902953853A8> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x922dc000 - 0x922ddffd libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
    0x922de000 - 0x922defff com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x92336000 - 0x92342ff8 libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
    0x92343000 - 0x92368ff7 com.apple.quartzfilters (1.8.0 - 1.7.0) <F6A88D89-AB4A-3217-9D65-C2C259B5F09B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x92369000 - 0x9236bffb libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x9236c000 - 0x9236cfff com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x9236d000 - 0x9236ffff com.apple.securityhi (4.0 - 55002) <62E3AE75-61CB-341E-B2A0-CFC985A2BF7F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92370000 - 0x923a0ff3 libtidy.A.dylib (15.10) <F2F4E000-E305-3089-91E6-3DB0ED07E74A> /usr/lib/libtidy.A.dylib
    0x923a1000 - 0x924bdff7 com.apple.desktopservices (1.7.2 - 1.7.2) <8E74D101-8398-34F1-A463-B4950680A597> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x924be000 - 0x924ffff7 libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
    0x9251a000 - 0x9251effe libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
    0x9251f000 - 0x92531ff7 libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
    0x92534000 - 0x92534fff libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
    0x9255b000 - 0x92571fff com.apple.CFOpenDirectory (10.8 - 151.10) <56C3F276-BD1F-3031-8CF9-8F4F481A534E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x92572000 - 0x9296efeb com.apple.VideoToolbox (1.0 - 926.62) <B09EEF06-CB3C-3EAA-8B0E-22A1801F3CAE> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x9296f000 - 0x92b57ff3 com.apple.CoreFoundation (6.8 - 744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x92b58000 - 0x92b8bff3 com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x92b8c000 - 0x92be3ff3 com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x92c15000 - 0x92c22fff libGL.dylib (8.6.1) <C7A3917A-C444-33CC-8599-BB9CD8C12BC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92c23000 - 0x92c2fffa com.apple.CrashReporterSupport (10.8.2 - 415) <BAE9900A-51E7-3AD4-A7FB-7E6CCFFB2F21> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x92c30000 - 0x92c7effb libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x92c7f000 - 0x92c7fffd com.apple.audio.units.AudioUnit (1.8 - 1.8) <4C13DEA2-1EB0-3D06-901A-DB93184C06F0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x92c80000 - 0x92c88fff libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
    0x92c89000 - 0x92c8cff7 libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
    0x92c90000 - 0x92d30ff7 com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x92d31000 - 0x92d35fff com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x92d36000 - 0x92d49ff9 com.apple.MultitouchSupport.framework (235.28 - 235.28) <5C8CFA21-D4FC-32E8-B199-0F7155E6ED9A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x92d4a000 - 0x92d51fff libsystem_dnssd.dylib (379.32.1) <6A505284-2382-3F27-B96F-15FFDACF004E> /usr/lib/system/libsystem_dnssd.dylib
    0x92d58000 - 0x92e70ff7 com.apple.coreavchd (5.6.0 - 5600.4.16) <F024C78B-4FAA-38F1-A182-AD0A0A596CBE> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x92e71000 - 0x92e96ff7 com.apple.CoreVideo (1.8 - 99.3) <5B872AC0-E82D-3475-A3F9-FD95F380560D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x92e97000 - 0x930efff1 com.apple.JavaScriptCore (8536 - 8536.26.7) <75629E05-65FE-3699-8CDC-80C95015CF42> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x930f0000 - 0x93152fff libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
    0x93153000 - 0x93180ffe libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
    0x93181000 - 0x931c3ffb com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x931c4000 - 0x931d4ff7 libsasl2.2.dylib (166) <D9080BA2-A365-351E-9FF2-7E0D4E8B1339> /usr/lib/libsasl2.2.dylib
    0x931d5000 - 0x931d5ffd libOpenScriptingUtil.dylib (148.2) <907E25B1-4F50-3461-B8D5-733C687EB534> /usr/lib/libOpenScriptingUtil.dylib
    0x931d6000 - 0x93216fff com.apple.MediaKit (13 - 659) <37B8C1E3-B67D-3FE6-8A14-7FFD9F31C556> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x93217000 - 0x9322eff4 com.apple.CoreMediaAuthoring (2.1 - 914) <37C0A2C7-73B3-39BC-8DE1-4A6B75F115FC> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x93d39000 - 0x93d47ff3 libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
    0x93d48000 - 0x93d97ff6 libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x93d98000 - 0x93ddaff7 libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
    0x93ddb000 - 0x944e2ff0 libclh.dylib (4.0.3 - 4.0.3) <36281EB0-2A92-3DCA-858D-698636E3B900> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x944e3000 - 0x9453aff7 com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x9453b000 - 0x9476bfff com.apple.QuartzComposer (5.1 - 284) <4E8682B7-EBAE-3C40-ABDB-8705EC7952BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x9476c000 - 0x949d9fff com.apple.imageKit (2.2 - 667) <3F5F92DB-C0C0-3C5F-98C6-B84AB9E28B55> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x949da000 - 0x94a1fff5 com.apple.opencl (2.1.20 - 2.1.20) <41C4AE6E-67B6-33E2-A9B6-BF6F01580B16> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x94a20000 - 0x94a21fff libdnsinfo.dylib (453.18) <41C7B8E2-2A81-31DE-BD8B-F0C29E169D4F> /usr/lib/system/libdnsinfo.dylib
    0x94a22000 - 0x94a9bff0 com.apple.CorePDF (2.0 - 2) <6B5BF755-F336-359C-9A99-F006F61442CF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x94a9c000 - 0x94b2effb libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x94b2f000 - 0x94b76ff3 com.apple.CoreMedia (1.0 - 926.62) <69B3835E-C02F-3935-AD39-83F8E81FB780> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x94c87000 - 0x95843ffb com.apple.AppKit (6.8 - 1187.34) <06EDB1D1-3B8A-3699-8E3A-D8F50A27AB7C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x95844000 - 0x9584cfff com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x95bc6000 - 0x95c16ff7 com.apple.CoreMediaIO (301.0 - 4147) <F13FA9D4-BD1D-3297-BDD5-5858B231D738> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x95c4d000 - 0x95c66fff com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x95c69000 - 0x95c73fff libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
    0x95c74000 - 0x95cf0ff3 com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x95e3f000 - 0x95e6cffb com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x95e6d000 - 0x95ff6ff7 com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x95ff7000 - 0x9601bfff com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x9601c000 - 0x96057fe7 libGLImage.dylib (8.6.1) <A3442557-18D5-332E-8859-423D5A20EBBE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x96058000 - 0x9605efff com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x9605f000 - 0x961b7ffb com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x961b8000 - 0x961bfffb libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
    0x961c0000 - 0x961c8fff com.apple.DiskArbitration (2.5.1 - 2.5.1) <25A7232F-9B6A-3746-A3A8-12479D086B1E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x961c9000 - 0x961ccffc libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
    0x961cd000 - 0x96211fff libGLU.dylib (8.6.1) <06BAFDCA-800C-35E3-B1A3-F05E105B86AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x96212000 - 0x96f4aff7 com.apple.QuickTimeComponents.component (7.7.1 - 2599.13) <85C70D1B-D074-3891-BF8D-9BA81D2C224B> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x96f4b000 - 0x96f6bffd com.apple.ChunkingLibrary (2.0 - 133.2) <FE5F0F1E-B15D-3F76-8655-DC2FE19BF56E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x96f6c000 - 0x96fabff7 com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x96fac000 - 0x97007fff com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x97008000 - 0x9701ffff com.apple.GenerationalStorage (1.1 - 132.2) <93694E0D-35D3-3633-976E-F354CBD92F54> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x97020000 - 0x970deff3 com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x970df000 - 0x9710bff7 libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
    0x97189000 - 0x971b3ff9 com.apple.framework.Apple80211 (8.0.1 - 801.17) <8A8BBBFD-496B-35A6-A26E-ADF8D672D908> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x971b4000 - 0x971eaffb com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x971eb000 - 0x971f5ffe com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x971f6000 - 0x971ffffd com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x97200000 - 0x9729afff com.apple.CoreSymbolication (3.0 - 87) <6A27BBE5-6EF0-3D5D-A485-2145826B9796> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x972a0000 - 0x972fbff7 com.apple.AppleVAFramework (5.0.18 - 5.0.18) <4BA2AAEA-4936-375C-B4D8-4BBE2EDC7FF5> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x972fc000 - 0x974b8ffd libicucore.A.dylib (491.11.1) <B19E450A-BAF1-3967-9C95-7F77DC0B4639> /usr/lib/libicucore.A.dylib
    0x974b9000 - 0x975b5ff3 com.apple.DiskImagesFramework (10.8 - 344) <98C16F91-9D3E-3FD0-A30B-BD49EE4ED9A4> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x975b6000 - 0x976b4ff7 libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x976b5000 - 0x97796fff libcrypto.0.9.8.dylib (47) <D4EFFCFB-206D-3E3D-ADB5-CBAF04EB8838> /usr/lib/libcrypto.0.9.8.dylib
    0x97797000 - 0x9780cff7 com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x9780d000 - 0x97844ffa com.apple.LDAPFramework (2.4.28 - 194.5) <8368FAE7-2B89-3A7D-B6EE-7184B522CB66> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x97845000 - 0x97852ff7 com.apple.HelpData (2.1.4 - 85) <1E180AEF-53FF-3D8B-9513-7FCA1B25A4AB> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x97853000 - 0x97853fff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x97855000 - 0x97856ffd com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x97857000 - 0x97c3aff3 com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x97c3b000 - 0x97cc3fff com.apple.PDFKit (2.7.2 - 2.7.2) <7AE7BAE9-4C21-3BFB-919E-5C6EEBBDFF75> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x97cc4000 - 0x97d5bff7 com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x97d5c000 - 0x97d5cfff com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x97d5d000 - 0x97db6fff com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x97db7000 - 0x97eabff3 com.apple.QuickLookUIFramework (4.0 - 555.4) <D66F61A6-2C4C-359F-A2E3-7D023C33CB5A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x97eac000 - 0x98538feb com.apple.CoreAUC (6.16.00 - 6.16.00) <654A0AB8-F24F-3489-8F70-F0A22414FE08> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x98539000 - 0x9853afff liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
    0x9853b000 - 0x98840ff7 com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x98841000 - 0x98841fff com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x98842000 - 0x9886bff7 libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x9886c000 - 0x9887afff com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x9887b000 - 0x98885fff libCSync.A.dylib (324.6) <D2E8AC70-C6D1-3C40-8A82-E50422EDCFBF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x98886000 - 0x988a2ff7 libPng.dylib (845) <14C43094-C670-3575-BF9B-3A967E05EAC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x988a3000 - 0x98979fff com.apple.DiscRecording (7.0 - 7000.2.4) <C14E99B9-DEFA-3812-89E5-464653B729F4> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x9897a000 - 0x98d0dffb com.apple.MediaToolbox (1.0 - 926.62) <7290B07B-4D03-3B46-809C-64C8FB97B40C> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x98d0e000 - 0x98d0efff com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x98d0f000 - 0x98d10fff libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
    0x98d20000 - 0x98d3affc libsystem_kernel.dylib (2050.18.24) <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
    0x98d8a000 - 0x98df9ffb com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x98dfa000 - 0x98e23fff libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
    0x98e24000 - 0x98e69ff7 com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x98e6a000 - 0x98f02fff com.apple.CoreServices.OSServices (557.4 - 557.4) <C724AB29-A596-3E1E-9FF1-A4E509AD843A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x98f03000 - 0x98f05fff libCVMSPluginSupport.dylib (8.6.1) <8A174BD9-992E-351D-8F9A-DF6991723ABE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x98f06000 - 0x98f31fff com.apple.shortcut (2.2 - 2.2) <FA94F2BF-37E1-3F16-9085-7BCCB815BAE9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x98f32000 - 0x98f40ff7 libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
    0x98f41000 - 0x98f56fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x98fbe000 - 0x99092fff com.apple.backup.framework (1.4.1 - 1.4.1) <55F2A679-9B21-3F43-A580-4C2ECF6A5FC5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x99093000 - 0x9919eff7 libJP2.dylib (845) <D409C913-6FA4-3D60-BFE0-B9FC6A02FEE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x9919f000 - 0x991a0fff libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
    0x991a1000 - 0x991edfff libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
    0x991ee000 - 0x9929dff7 com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x9929e000 - 0x992a5fff liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
    0x992a6000 - 0x992a6fff libSystem.B.dylib (169.3) <81C58EAB-0E76-3EAB-BDFD-C5A6FE95536F> /usr/lib/libSystem.B.dylib
    0x992a9000 - 0x992c8ff3 com.apple.Ubiquity (1.2 - 243.10) <D2C9F356-1681-31D2-B292-5227E2DDEB0B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
    0x992c9000 - 0x994e0fff com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x994e1000 - 0x9963effb com.apple.QTKit (7.7.1 - 2599.13) <2DC9E2BB-9895-3D02-A318-88431052E70B> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x99642000 - 0x99645ffd libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x99648000 - 0x99739ffc libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
    0x9973a000 - 0x99741ff3 com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x997b4000 - 0x997c9fff com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x997ca000 - 0x998b3ff7 libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
    0x998b6000 - 0x998e9ff5 libssl.0.9.8.dylib (47) <3224FBB3-3074-3022-AD9A-187703680C03> /usr/lib/libssl.0.9.8.dylib
    0x99b84000 - 0x99b88ffc libGIF.dylib (845) <714E9F0D-D7A3-3F58-B46E-FCBE0F144B23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x99b89000 - 0x99ea6ff3 com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x99ea7000 - 0x99fe2ff7 libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x99fe7000 - 0x99ff3ffe libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
    0x99ff4000 - 0x99ff4fff com.apple.Carbon (154 - 155) <604ADD9D-5835-3294-842E-3A4AEBCCB548> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x99ff5000 - 0x9a05dfe7 libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x9a05e000 - 0x9a0c2fff com.apple.datadetectorscore (4.0 - 269.1) <4D155F09-1A60-325A-BCAC-1B858C2C051B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x9a0c3000 - 0x9a1d0ff3 com.apple.ImageIO.framework (3.2.0 - 845) <BF959BCB-C30A-3680-B7C2-91B327B2B63B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9a1d1000 - 0x9a1daff9 com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x9a1db000 - 0x9a1dffff com.apple.IOSurface (86.0.3 - 86.0.3) <E3A4DB0A-1C1A-31E3-A550-5C0E1C874509> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x9a1e0000 - 0x9a1edff7 com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x9a1ee000 - 0x9a2e6ff9 libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
    0x9a2e7000 - 0x9a58affb com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x9a58b000 - 0x9a5a8fff libxpc.dylib (140.41) <1BFE3149-C242-3A77-9729-B00DEDC8CCF2> /usr/lib/system/libxpc.dylib
    0x9a5a9000 - 0x9a5c7ff3 com.apple.openscripting (1.3.6 - 148.2) <55738D66-CC15-3F43-9265-00C3322D39C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x9a5fe000 - 0x9a608fff com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x9a609000 - 0x9a60afff libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
    0x9a60b000 - 0x9a628fff libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
    0x9a629000 - 0x9a634fff libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
    0x9a635000 - 0x9a677fff libcurl.4.dylib (69.2) <8CC566A0-0B25-37E8-A6EC-30074C3CDB8C> /usr/lib/libcurl.4.dylib
    0x9a678000 - 0x9a69cfff libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x9a69d000 - 0x9a69dfff com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0xb0000000 - 0xb0050ffb +com.canon.edsdk (2.11.3.0 - 2.11.3.0) <AC8BDFED-33A3-1E56-01A5-2BC458B77806> /Applications/MadMapper.app/Contents/Frameworks/EDSDK.framework/Versions/A/EDSDK
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 2
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 543
    thread_create: 2
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=237.0M resident=117.8M(50%) swapped_out_or_unallocated=119.2M(50%)
    Writable regions: Total=157.7M written=10.4M(7%) resident=45.5M(29%) swapped_out=0K(0%) unallocated=112.2M(71%)
    REGION TYPE VIRTUAL
    ATS (font support) 32.0M
    ATS (font support) (reserved) 4K reserved VM address space (unallocated)
    CG backing stores 6016K
    CG image 360K
    CG shared images 1184K
    CoreImage 4K
    CoreServices 2352K
    IOKit 9368K
    MALLOC 76.0M
    MALLOC guard page 48K
    MALLOC_LARGE (reserved) 2048K reserved VM address space (unallocated)
    Memory tag=240 4K
    Memory tag=242 12K
    Memory tag=249 156K
    Memory tag=35 2376K
    OpenCL 8K
    OpenGL GLSL 896K
    Stack 68.1M
    VM_ALLOCATE 16.2M
    __DATA 14.4M
    __DATA/__OBJC 224K
    __IMAGE 528K
    __IMPORT 4K
    __LINKEDIT 37.3M
    __OBJC 2648K
    __OBJC/__DATA 56K
    __PAGEZERO 4K
    __TEXT 199.7M
    __UNICODE 544K
    mapped file 70.1M
    shared memory 2112K
    TOTAL 544.0M
    TOTAL, minus reserved VM space 542.0M
    Model: MacBookPro6,2, BootROM MBP61.0057.B0F, 2 processors, Intel Core i7, 2.66 GHz, 4 GB, SMC 1.58f16
    Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
    Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
    Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x802C, 0x31364A53463235363634485A2D3147314631
    Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x802C, 0x31364A53463235363634485A2D3147314631
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.81.22)
    Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
    Network Service: TracyIsland, AirPort, en1
    Network Service: Ethernet, Ethernet, en0
    Serial ATA Device: Hitachi HTS545050B9SA02, 500.11 GB
    Serial ATA Device: MATSHITADVD-R UJ-898
    USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
    USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 5
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8218, 0xfa113000 / 7
    USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa130000 / 4
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0xfa120000 / 3
    USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
    USB Device: Canon Digital Camera, 0x04a9 (Canon Inc.), 0x3217, 0xfd130000 / 5
    USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0xfd110000 / 4
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
  • antenasenflor
    Re: Image quality should be set to jpeg only
    by antenasenflor » Wed May 01, 2019 1:29 pm
    I have the same problem with a canon 550D.
    Did someone contact you in order to sholve your problem? Did you find any way to make it work??
    by franz » Tue May 07, 2019 4:47 pm
    3.7.0 beta was updated to use the latest canon sdk.
    please try it and report back in case it doesn't work.
