Arnet and preset
  • fekril
    Arnet and preset
    by fekril » Sat Jan 26, 2013 2:19 pm
    Hello, I have a bug with 1.4 /1.3 and my artnet interface, I create a fixture it correctly address my interface, my strip led is ok but when I create or change preset, the interface does not work anymore, I have to revalidate preferences it works again, you have the same symptoms :?:
  • fekril
    Re: Arnet and preset
    by fekril » Sat Feb 02, 2013 9:46 pm
    The same with 1.41 pfffffffff :evil:
    by franz » Tue Feb 05, 2013 12:10 pm
    please contact the support, we have a build that corrects the problem
    by franz » Wed Feb 20, 2013 1:54 pm
    solved in 1.4.2
