syphon
    tdog
    syphon
    by tdog » Fri Feb 01, 2013 1:51 pm
    so,
    i downloaded syphon simple server and simple client..
    if someone could explain the routing procedure, i would be most happy...
    thanks.
    tdog.
    By any means necessary....
    orion
    Re: syphon
    by orion » Wed Feb 06, 2013 7:30 am
    what are you trying to syphon and what are you trying to syphon it into?
    Re: syphon
    by The Midi Thief » Sun Feb 10, 2013 4:47 pm
    so,
    thanks.
    tdog.
    These programs are not needed to run Syphon, they are just test programs.
    If you want to test the Syphon input in the Modul8 2.7 beta:
    - Run the Simple Server app.
    - Go to Modul8, select a layer, go to your Media Set's SP tab and pick Syphon.
    - Now you should see the Syphon logo that's being sent from the Simple Server.
    If you want to test the Syphon output from Modul8:
    - Have some media running on a layer (or why not a test card?).
    - Select Syhon output under (cmd+Y)
    - Go to the Simple Client app and pick "Main view - Modul8" from the drop down menu.
    tdog
    Re: syphon
    by tdog » Wed Feb 13, 2013 7:32 pm
    Thanks bloke...
    tdog.
