Blackmagic Ultrastudio Express HDMI input
    pele2010
    by pele2010 » Sun Feb 03, 2013 7:14 pm
    Hi ,
    i tried to connect on MBP with a second via THunderboldt (HDMI) output (720p).
    i then connected this via HDMI with the BMUS. HDMI input .
    The BMUS is then connected with the 2nd MBP via Thunderbold.
    I checked the output of the first MBP. The monitor tells me that it´s 720 p 50Hz.
    Everything fine.
    Then i launch M8 and it worked .... I was very happy. I took a picture and a movie.
    I had to shutdown the computer and then at the second time. MBP 1 doesn´t show up.
    Does anybody have the same problem ?
    It would be great if i could get some help.
    My Head is burning because it could be so many things ... Not the right video format / Driver not working correctly /
    I startet QT 7 and locked for the blackmagic. But no input ....
    I restarted the output several times to make sure that the signal starts again.
    Any help would wonderful
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    Re: Blackmagic Ultrastudio Express HDMI input
    by pele2010 » Sat Nov 22, 2014 5:11 pm
    Ok,
    with the new 2.9 Alpha i got it working.
    Now i can run on the 1st MBP > output the display signal > to HDMI ultra studio express (only 720p)
    With the BUE connected to the 2nd MBP > Camera input (detect)
    And it works great and with no latency (very,very little)
    But i can´t with to 1080p (pal 50 Hrz)
    Does somebody know why ?
    I can select the 1080 p on the first MBP but the i don´t get a "detect" on the second.
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    by pele2010 » Mon Nov 24, 2014 9:27 pm
    Hey after testing some more time i found out that i need to take 1080i with 60 Hrz
    With this i was able to input the output of MBP 1 and input it in MBP 2.
    At the beginning the Latency is nearly 0 (1 frame or 2 frame)
    the longer the connection is established the bigger gets the latency.
    (any suggestions to minimize this?)
    The only thing i bother is that the alpha down´t come through.
    Anybody out there that has solved this problem ?
    is there a blackmagic that is able to transfer the alpha too?
    would be great....
    i will post some pictures.
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • skdenisetomlin
    by skdenisetomlin » Wed Oct 17, 2018 3:44 am
    Hello Pele,
    I think this problem is because of all about configuring your HDMI splitter. You may check out your device user manual to solve this issue. I had one. I'm using it since 2015. I'm fetching some technical problem with it. I need another one. I figure out this page best wireless HDMI transmitter and receiver. Can you suggest me which one will be the best?
    Thanks. :lol: :lol:
Users browsing this forum: Baidu [Spider] and 53 guests
