Two controller at the same time
  • te-c
    by te-c » Mon Feb 04, 2013 7:22 pm
    Since today I always used a BCF 2000 as my favourite controller but I invest in an iPad and will use it over Touch OSC MIDI Core with the Two way Midi Module from udart.
    It would be great if I can use both controller for modul8 and programmed both. I have a Fader on the iPad that works with feedback and have a fader on the BCF that works with feedback. I have only one problem. If I use the fader on the iPad the Fader in Modul8 works but don't react on the BCF. The same is in the other direction. If I use the Fader on the BCF it reacts in Modul8 but not on the iPad.
    Anybody have an idea? Why the Midi-devices can't communicate to each other?
    Vibeke in your manual you say that there are some workarounds with multiple controllers. Did you ever checked the BCF and an iPad via Touch OSC?
    I don't use the OSCulator, I'm using the Core MIDI version.
