2.7b Art-Net Question (X-POST)
    gmint
    by gmint » Fri Feb 08, 2013 6:35 pm
    Has anyone gotten Art-Net working with the 2.7 beta? I posted in the support forum and contacted support directly but I haven't heard anything back in about a week. I'd just like to know if anyone has had success with this!
    DJ G Mint
    pele2010
    Re: 2.7b Art-Net Question (X-POST)
    by pele2010 » Fri Feb 08, 2013 11:39 pm
    Hi Gmint,
    i tested it, but the grandma operator wasn´t that experienced, so i saw a feedback in M8 but
    i couldn´t connect it. I couldn´t figure out how to rout the channels.
    i think that to get this working you need a module that does the job.
    any other help on this ?
    would be great and helpful.
    thanxs
    pele2010
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    gmint
    by gmint » Fri Feb 08, 2013 11:46 pm
    I think I understand the DMX module (which I think is what you need), but it's good to know that you were seeing input from Art-Net. Can I ask though, when you say you were seeing feedback in Modul8, where were you seeing it?
    DJ G Mint
    pele2010
    by pele2010 » Sat Feb 09, 2013 1:46 am
    Hi gmint,
    it´s under cmd alt i (module8 menue > info )
    three tabs ;: general / dmx / midi
    hope you have more luck ....
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
    gmint
    by gmint » Sat Feb 09, 2013 7:44 pm
    Well I'll be damned. I had no idea that window was there. I guess you learn something new every day. Thanks for the info! At least that gives me one more troubleshooting tool!
    DJ G Mint
    pele2010
    by pele2010 » Sat Feb 09, 2013 8:56 pm
    Hi gmint,
    i had the chance to see this while other where setting up lights with m8.
    I had no clue what they where doing , but i can remember "menue" functions quite well.
    as beta tester for "avid media composer" interface, this was my job.
    i got a massage from garagecube, that if you whant to control m8 with Artnet (DMX) you need
    to use the dmx fixtures module. (page 132)
    i can´t test this at the moment. so i hope you get this done.
    thanxs
    pele2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
    by boris » Sun Feb 10, 2013 5:17 am
    You got a massage ahah you'r lucky !
    Btw : Gmint sorry for the delay of my answer on the support,
    I'm using the Artnet since a while with succes it's the same way to use than DMX but I did not tested all configurations so you'r feed back are important.
    Boris.
    pele2010 wrote:Hi gmint,
    thanxs
    pele2010
    gmint
    by gmint » Mon Feb 11, 2013 5:44 pm
    Boris,
    As I indicated in my reply to the support ticket, my belief at this point is that Modul8 is working correctly with Universe 0 (which, for some reason, my lighting software doesn't send) but that higher universes do not work.
    DJ G Mint
    by boris » Mon Feb 11, 2013 7:12 pm
    Hi !
    I'm out of office this week,
    I will do testing next week, to see if we have the same problem, and fix it if there is.
    Thanks,
    Boris.
    gmint wrote:Boris,
    david
    by david » Wed Feb 20, 2013 2:29 pm
    Hello gmint,
    gmint wrote:Modul8 is working correctly with Universe 0 (which, for some reason, my lighting software doesn't send) but that higher universes do not work.
    There was a bug in the OSX version of QLC+. I have corrected the bug for their ArtNet plugin on OSX and submitted it to the developer. I sent you a patched version of QLC+ on the support.
    Regards.
