madlight artnet sending color even though video is b&w
  • soupvisuals
    by soupvisuals » Sat Feb 09, 2013 11:03 pm
    So just got artent running with 6 elation pars for first time and they are rocking all colors even though the video file is black and white.
    the preview within madmapper of the artnet output also shows color even though clip is black and white
    photo has only blue chanel up so that is only color coming up,, with all color bars on all flash instead of it just being black and white.
    with all off and luminosity up all lights go black
    Screen Shot 2013-02-09 at 4.02.00 PM.png (198.81 KiB) Viewed 4219 times
    Re: madlight artnet sending color even though video is b&w
    by boris » Sun Feb 10, 2013 12:37 am
    Hi could you send a message to the support including a link to download your project file ?
    We don't have this problem here, and your exemple is not relevent, if you supress the red and the green white become blue (W = RGB)
    Anyway send a mail to us and we will try to figure out.
    Also the famous question : What version of Madmapper are you using ?
    Best Regards,
    Boris.
    Capture d’écran 2013-02-09 à 23.32.07.png (71.83 KiB) Viewed 4215 times
    by boris » Sun Feb 10, 2013 12:39 am
    And now there is the result if I supress the Red and Green...
    Capture d’écran 2013-02-09 à 23.32.23.png (71.32 KiB) Viewed 4215 times
