This is a known bug in the Canon SDK we use in MadMapper it could freeze OSX and/or your camera. For OSX freeze, you will have to reboot. For DSLR freeze, you will have to power off, remove the battery.I had to reboot if you unplug the camera while running the program(MM 1.3)
You could also use USB webcam that are compatible with QuickTime. You could simply use the integrated FaceTime HD webcam of your MacBookAir. However you will get a poorer result than with a Canon DSLR.Does Spatial Scanner require only FireWire cameras or can I use a USB3.0 camera/webcam? Also, can anyone recommend one? Thanks.
