Modul8 2.7 beta 2 available for download
  • garageRoot
    by garageRoot » Fri Feb 22, 2013 7:17 pm
    Modul8 2.7 beta 2 is now available for download from the Modul8 yourspace page.
    Fixes:
    - A potential crash due to the Flash plug-in. Now the plug-in will only initialize if Flash media is used.
    - A Layerset selection problem and potential random behavior due to an issue in the keyword module feedback.
    - Some issues with module download, registration, authorization and de-authorization with non-latin languages (Arabic, Chinese, Japanese…) and when unexpected space characters are used in the serial number.
    - An issue when switching document/default midi configurations in preferences
    - An issue in updating the display of the midi mapping when importing a midi mapping
    - An issue in the path of media when a project is saved with the media collector
    Added:
    - Module function: sendDMX has a new special value: -1 for the subnet/universe Art-Net used in the preferences. Example: sendDMX(-1, channel, value). Some DMX modules have been updated in the GarageCUBE online module library.
    - Native support for the faderfox MicroModul8 midi controller in the main interface (not yet implemented for the module system user interface) including special behaviors for the controller: midi feedback, preset management and preferences
    - New module keywords: 'info_mm8_detected', 'info_mm8_preset', 'info_mm8_nativeSupport', 'info_mm8_defaultChannel'
    - Added the MIDI source parameter to Module directEvent feedback
    Changes:
    - Shows a message when a version limit time is reached
    - OS X Minimum requirement is now 10.5 or greater
    Note:
    - This version is time limited to 31/12/2013
    - "Art-Net™ Designed by and Copyright Artistic Licence Holdings Ltd"
    Modul8 2.7 beta 2 is available to all existing Modul8 license holders. To download it simply log into the Modul8 yourspace page using your serial number:
    http://www.modul8.ch/yourspace
    Important note: This version of Modul8 is for testing purposes only. Do not use it in a production environment.
    Your reports are very important to us. Please send us step-by-step procedures on how to reproduce the bugs you may be experiencing along with your system configuration to support [at] garagecube [dot] com.
