is there a way to limit the artnet output rate to a specific value (in Hz)?
My artnet fixtures are sensetive to high framerates (over 50Hz).
Greets
Is this the Arduino project?No, my fixtures have direct artnet input, but madmapper has a high framerate output which fills the buffer of their network interface too fast. The processor which is an Atmel 8Bit can't process the packets so fast.
I'm currently in contact with the developer of it. He said that all other software products have abilities to limit the framerate and are able to use artnet unicast.
I ran into the same issued you did with the UNO. I picked up a Mega today and will have to plug that into the strips at work on Monday. Honestly if this works, and this replaces our Enttec Open DMX Ethernet ($275) and a DMX Decoder Box ($40), that's a huge savings /per universe. $60 Mega and $22 Shield. $233 savings per universe.Yes, it's the LED stripe artnet node.
It works well on Arduino MEGA (because of its processing power) but causes hangs on UNO on large packet bursts. We are currently debugging the problem with the developer.
